DQG 18650 EDC--World's Smallest 18650 Flashlight
Unscrew bezel
Remove TIR lens
Take O ring off the groove on the front of the lens
Insert lens into bezel then drop O ring into place on the back of the lens
Put the bezel back on……done
Yes, it’s much smaller than the Xiaozhi, but not as tactile (not tactical) as the C303.
I don’t have an SC52, but do have these:
DQG AA, 270-T80, Xiaozhi, Convoy S2, DQG Tiny 18650, UF-2100, C303, Ultrafire S5, Small Sun ZY-C1 (16340)
— DELETED —
Hi RIC,
Actually, so this brings up a question: The original place where the O-ring was had a groove, like it was meant to have an O-ring there. Since we’re removing the O-ring from the TIR lens, is the water-proofing still intact? Seems like water could enter from the front of the lens?
Thanks, and thanks also for these lights!
Jim
BTW, the clip looks very nice!
Wow! Much nicer hotspot and flood area now :slight_smile:
I’m a little confused. Are we using BOTH white o-rings. The one wrongly installed at the factory AND the one that came loose in the box? The first one going behind the lens instead of in the groove in front of the lens. And the second one going on the threads connecting the upper body to the bezel as shown in Ohaya’s picture?
I think it’s not both, but rather move the one that is on/around the TIR lens to the threaded area, but then, there’s the question I posted about what waterproofs the lens/bezel area.
Apparently when the O-ring was around the TIR lens, it was causing some rings on the beamshots.
Thanks for the measurements. Well that’s bizarre—the black version has a larger tube diameter?? Why would they bother to machine a different tube for the outer coating? Unless it was outsourced and the manufacturer allowed some variance in the boring.
I do not have the light yet, but I'm sure the o-ring does not go around the threading (photo is wrong), but goes around the underside of the tir. When the bezel is screwed on it sits on top of the head part, not around it.
OK, so the white o-ring that came in the box is just a spare and is not needed on the threads.
Thanks djozz
Hi,
Oh. You’re right. That makes more sense plus answers my question (also matches RIC’s original drawing, I think):
I got two lights, and there’s one extra white O-ring, and a different number of the smaller black O-rings in the boxes.
Exactly. That's how I did it. This way the TIR is located slightly higher / further away from emitter, and it works! Plus the construction is still water tight, even more than the original. :)
Hi,
I got two of these lights, and, FYI, one of them, the black one, already had the O-ring in the right place. I only had to move it one my Titanium one.
Jim, please delete your post or picture so it doesn’t confuse people with the incorrect information. :wink:
Great size comparison, thanks for the awesome pic
+1 to the above. It puts it in perspective very well. Thanks Suncoaster.
My black DQG 18650 with neutral T6 arrived today.
Initial thoughts:
*Very lightweight and small for an 18650 light
*Feels good in the hand. Nice size and quite grippy.
*Very nice beam pattern with good tint.
*The clip was VERY hard to remove. That sucker didn’t want to come off at all. I had to pry it off with a screwdriver. This caused a few scratches to the anodizing around the top edge of teh clip slot. Even though this isn’t a screwed on clip, if you use it for pocket carry I think there is very little chance the clip would come off accidentally.
*Upon receiving the light, the bezel o-ring needed to be reinstalled as it was in the wrong position. This was expected based on the earlier notice from Ric.
*The head turned extremely easily when I received the light. Close inspection revealed that there was only 1 o-ring between the head and the body even though there was a second slot. I grabbed one of the spare black o-rings from the box and stuck it in this slot to give much better tension between head and body.
*It is hard to reliably change modes without 2 hands. One-handed operation seems to often result in jumped modes.
*I haven’t tested it yet, but I doubt this light will work with flat top cells.
Done.
