I want to buy that driver circuit!
Hope it becomes available and that I can use the coupon code on that.
Looks nice, wonder if it can be operated remotely via bluetooth, I could really freak the wife out then
Snap, just saw your post pyro
When I get the 10$ Coupon, I think I will get one
On the product page, there is no word about a low battery indicator. Will it have one?
Flashlight made easy now, look at the cellphone if it has enought battery change modes
I guess 4Sevens unique product is not unique anymore.
no IOS or Mac supportedā¦
fastech has also an android app, again no IOS. they hate fanboys
Why support obsolete software?
i am obsolete myself, why donāt they support me?
Because you are obsolete.^^
Yes you can, and itās just a simple tap away. But by āremoteā weāre talking 10 feet max and at that distance the flashlight has to be placed within a certain āangle of attackā.
Compassionate nightcrawl
Thats it, I flat out have to have one now, coupon code please :bigsmile:
IĀ“m a cowā¦ to be fair, a cow using a mac is less obsolete than an average cow
Yes you can, and itās just a simple tap away. But by āremoteā weāre talking 10 feet max and at that distance the flashlight has to be within a certain angle pointing at you.
$10 discount redeeming method described here now: *Name your favorite reviewers* for a $10 coupon towards a cool new flashlight
Clever stuff. It would be nice if it had a tripod mount, since it can be remotely operated. I hope the GITD button can be easily replaced - I think it looks cheap. (yes, I know it is cheap, especially with the coupon). 8)
ordered, blf coupon applied and 10% refunded as per coupon promise.
mrs gords is going to kill me.
Ordered
wowā¦ is this where the future of flashlight is going? :bigsmile:
very uniqueā¦ but is that mean you canāt no longer swap the driver then?
When looking at a single picture. The tint can never be judged. Its a mostly a matter of white balance. A warm beam can be made to look cool, and a cool beam can be made to look warm depending on the white balance.
If you see the pictures FT have with WW emitters, they do not look WW. CW, can sometimes look neutral.
I have even seen FT pictures where WW emitters look cooler than CW emitters.
A comparison between two flashlights side by side on the same picture is the best way to get a comparison. But you can not be sure any if the colors are correct compared to what the eye see, you only see the difference. That is, unless the white balance is fixed or known and the beam is on a white wall and your monitor is properly calibrated.
Considering that the emitter is 1C, the beam should be a bit blue-ish. In my monitor, and with my eyes, I would consider the color in the beam shot to be around 5000K, which is not the case. I would describe the beam to look neutral in the middle, slight yellowish on the edge of the hotspot, and slightly cool spill.
I would expect that the light have the same characteristics, but everything would be cooler.
Its a shame FT have not managed to get this light with better XM-L2s (yet).
3C tint?
Only glass lens? Why not AR coated?
