As I understand it, Fasttech has already acquired patents on the technology and idea. I know the owner is extremely wealthy and will bet he will do what is needed to protect his investment.
Out of curiosity is anyone planning on trying to port the android app to ios? Sadly I don't really know enough to do so, but I certainly plan on playing around with it and seeing what I can get to work.
Because I’ve had some conversations with fasttech prior to this light being announced. You already know most all about this one now but if I told you what I know about the next lights I’d have to kill you. :bigsmile:
Nice light! Out of my budget though, after dropping $50+ each the last two months on lights. If there was a way to transfer my coupon code to someone else I’d do it.
the T08 has 635 lumens output, whereas the Asgard is spec’ed at 1052 lumens and 3040 mA. So, other than the Bluetooth stuff, have they added more 7135s to the Asgard to get to the 1052 lumens (vs. the T08)?
the Asgard is driven with 8*7135 at 260mA each. The original t08 was only driven at just over 2A and didn’t use 7135 chips.
12.5% increments with zero pwm means that each AMC chip can be activated one at a time directly. Modes other than 12.5% increments use pwm to control output at any level you choose. I hope this answers your question. :)
Between your response and Bort’s, yes :)… Do you think the 7135s would be stackable then (assuming spacing available and emitter can take the current)? And then the increments would be 2x each?
If you could figure out which pad locations are used in for each mode, you could stack chips only onto the locations that will increase one particular mode... if you just doubled all of them, all the modes would be 2x original current.
(assuming there isn't any cleverness going on like randomizing which 7135s are in use on each mode change)
Your last sentence (the one in parentheses) is true. I hadn’t thought of that, that one 7135 is just the same as the others, plus they’d probably tie all the outputs together, right? But, why would they even do that?
7135 outputs in parallel wouldn't affect anything at all, no current flows in or out of the ones that are inactive. They're like solid state relays, in that they only 'open the valve' that lets electrons flow when a signal is applied to the Vdd pin. The chips themselves are the same but they have separate traces connecting their Vdd's to the microcontroller, if as claimed they control them all independently to get a 12.5% increase each time one more 7135 is switched on.
