If you could figure out which pad locations are used in for each mode, you could stack chips only onto the locations that will increase one particular mode... if you just doubled all of them, all the modes would be 2x original current.
(assuming there isn't any cleverness going on like randomizing which 7135s are in use on each mode change)
Your last sentence (the one in parentheses) is true. I hadn’t thought of that, that one 7135 is just the same as the others, plus they’d probably tie all the outputs together, right? But, why would they even do that?
7135 outputs in parallel wouldn't affect anything at all, no current flows in or out of the ones that are inactive. They're like solid state relays, in that they only 'open the valve' that lets electrons flow when a signal is applied to the Vdd pin. The chips themselves are the same but they have separate traces connecting their Vdd's to the microcontroller, if as claimed they control them all independently to get a 12.5% increase each time one more 7135 is switched on.
That’s the thing with ‘technology’. Of course you can wait. In the future everything is going to be better (than now) definitely. But what’s important is you get to ‘enjoy’ it now, and by ‘enjoying’ it now, you fuel the next wave of improvements, because when there’s sales, then there’s incentive for Research and Development.
Let’s say iPad just launched… decided wait for the next one cause it’s not stable… okay iPad 2 comes out… hmm still not perfect… ok let’s wait some more… iPad 3… iPad 4… iPad 5 so wait forever and never got it. (Just using iPad as example, you get the point of the ‘endless wait’ cycle)
Sure, after a few months probably something better’s gonna come out, so that’s where the dilemma comes in. To buy now or to buy in future.
I do strongly suspect that you’ll play with the bluetooth settings till you find your ideal set up, then just use it as a torch, that said, I’ve voted with my wallet as this is to me, the most interesting development in torch tech since high output led’s, yes the zy-t08 is much cheaper, I have one, driven harder than this flex is, its a very very good pocketable thrower (jacket/cargo pocket), I just see this new driver making a very good light a great light and dont want to see the idea fade into obscurity due to lack of support.
I also suspect one of the reasons for using the zy-t08 is the huge aircraft sized empty driver cavity, as I doubt this driver and its associated modules is miniaturised yet, I’m very excited to take a peek under the hood.
And I thought that having modes at all in a flashlight was already a certain sign of civilization soon ending. So now those modes are bluetooth controlled...
from the sound of it, even on off is bluetooth controllable, I’m quite interested to see the app and what you can change about, its not available yet though, I’ve looked
that’ll be difficult, you have to unscrew the head to change the cells, I’m interested in a blank contact board though, because that’s surely what they’ve used for this.
That was why I was asking/suggesting about alpha/beta. I have the FT app on my Samsung Galaxy player, but it FCs intermittently. I think I reported via a ticket, but was suggested to just auto-report via the app itself.
True. :P Sadly the MK-802 doesn't support bluetooth (no hardware and doesn't support a bluetooth adapter). I still think Fasttech should release an iphone version (preferably one for jailbroken iphones with a quick access toggle).
Man FastTech keeps kicking tail. I'm curious about the development process and who was all involved. I don't need to drop another $60 on any light, but this looks quite impressive. Cool to see that it separately turns on 7135s as well.
No offense but adding a BT interface isn’t really that difficult in the large gist of things. It would require redesigning drivers from the traditional norm but it could easily be done by the right people. People have been putting BT programming units on things longer than you might have thought of ;).
Making the App’s to control it and the code to interface with it may very well be able to be controlled by the person/corp who made it, however others could just as well make their own.
It looks cool, however I would still like the full metal + AR coating. Is there a way to have it so that it’s programmable, but not really useable outside of a few inches? The choice of host (Body thickness/Mounting, rings, etc) might make a difference too. Or an external antenna could be routed, or wrapped around in the body.
