Don't worry about it Don. It's going to cost you an arm and a leg or both arms and legs to ship anything my way. I'll be happy just knowing that I actually got it right. I had to download the pic, zoom-in and study it very, very closely. LOL
Edit: I just double-checked and I did order 5 of these BLF DeLights. :bigsmile:
Now the hotspots are clearer. They ought to be - this is a 7 megabyte image.
You can just make out the bluish hotspot of the Powerlight on the left just on the Y shaped crack in the ceiling. It is much less bright than the three DeLights around it.
I have one of the MXDL T-51 on order from 'go_market' (e-bay). You can go to their store & find this light in red or in a 2 pack containing 1 black & 1 red. If you look around on their site you can find the most advantageous price. If it turns out to work as good as it looks I might order a few more. If these lights are as good as a Romisen I'll be happy.
The MDXL one just arrived - I think the C3 alike is in the PO waiting for me - if i read the card correctly there are 9 packages that wouldn't fit through my letter box.
First impressions:
It is heavier than it looks 67g with an Eneloop whereas the Powerlight is 56 with an Eneloop.
Visually, it appears to be very long for a single AA light - roughly 12mm 1/2" longer than a Powerlight.
It has a wide (for a single AA light), but rather shallow reflector.
It appears slightly dimmer and rather bluer than the Powerlight. Throw 228 lux at 1 metre - Powerlight 350
The lightbox numbers are much closer - 81 for the MDXL versus 83 for the Powerlight. These are well within the bounds of experimental error.
These numbers came from freshly charged Eneloops - both will likely be brighter with alkalines but I only have part-used or dead ones lying around. This light will possibly run for longer than the Powerlight - will look at current draw once I've lubed the threads. The Powerlight may, or may not have come unlubed but it certainly is now and feels very much nicer than the MDXL. The threads had a lot of filthy stuff in them. They no longer graunch, but the Powerlight feels far nicer.
This one isn't going to tailstand. Even with the lanyard removed and the switch is like the BLF DeLight one - you aren't modifying that one...
The head unscrews as a unit. It was clear from the positive contact that accountants sere involved in designing it. "No you can't have hardened stainless steel in there, it's too expensive. Use case-hardened butter instead."
But for the price which is less than a bus fare from where I live into the centre of town (maybe 3 miles) should I complain...
Well I did anyway. The extra 70 cents for the Powerlight is worth it IMO.
The light. As you can see, it is long for an AA light.
Compared with other AA lights. It is longer than the humungous Trustfire F22 - but a lot lighter. The lights are:
BLF Cheapskates' DeLight
Trustfire F22
MDXL T51
Powerlight
Ultrafire C3 stainless steel.
It is surprisingly heavy - the tube walls ought to be strong.
The bencounters' delight positive contact. Nasty!
The non-moddable tailcap - same as the BLF DeLight but it is 1/3 of the price. The hard plastic goop in there is actually white - the exposure and colour balance are a bit messed up.
I thought it looked oddly like the BLF DeLight tailcap. It does - as it is interchangeable with them... Tested with 3 different DeLight tailcaps and all of them worked properly with this light. Odder and odder.
The business end. The LED looks almost like a 5mm type - but they don't have 6 bond wires into them like this one. No idea what sort of LED it is, but I suspect it'd be epoxy vapour if you put 3 watts into it.
Do I like the light?
Not much
Do I want to kill it with a 14500 - nah, it isn't that bad. Guess some kid's getting a flashlight on the next gift giving occasion.
It even works with the tailcap that won't work on any of the DeLights so I now have 8 working DeLights. Actually 7 as I gave one to a patient of mine, along with a cup of coffee using up the last of the office coffee - I did warn him that if I forgot to get more coffee for Monday, I'd have to kill him. Fortunately for him, I remembered and gave him a DeLight instead.
Great, thanks for the review Don! It looks rather nice for the price in my opinion, but if I were to review it using my criteria, I'd probably give it 4/5 stars for Features / Value, and obviously 5/5 to the DeLight. Yes, it's a bit too long, and I don't know why they don't make more tailstandable lights.
I think the tailcaps came out of the same factory - even if the lights didn't. I can imagine a factory in China churning out cheap switch and tailcap units to be used by whoever wants them. It is the threading that makes me think this. There is no reason for them to be the same otherwise.
Just checked and the DeLight/MDXL tailcaps also fit and work with the Powerlight. The Powerlight tailcap does not work with the MDXL though as the spring on it isn't long enough to reach the battery.
Should have pretty good runtime, then. I guess that's the secret to the Powerlight's great runtime-- low amperage. For me the Powerlight's output is often more enough. Did you ever compare the Powerlight's beam quality to, say, the AA-S1 or the R5-A3? My two Powerlights have absolutely stellar beam quality. Obviously brightness is incomparable, though.
I thought the LED looked the same as the one in the Powerlight. So I fiddled around withe the camera to get a picture of the bond wires. This took about 3000 lumens shining into the reflectors (and back into my eyes) while I tried to get focus on the LEDs. The Powerlight is on the left, the MDXL on the right
The arrangement of the wires in the LEDs does look different so I imagine they were made in a different place, though they look very similar to the naked eye. I had to mess around a lot with contrast and so on to make the wires inside the LEDs visible at all.
Will try that once it is a bit darker - though it's been a dim, grey and overcast day with plenty of rain all day. Official sunset is 8.5 hours away - currently 3:30pm here
For me, the DeLight has better brightness, worse runtime, an uglier beam, and poorer quality. The Powerlight has a much nicer beam, less brightness, much better runtime, and slightly better quality. So basically you get what you pay for, and I like them both for the price.
My MXDL arrived yesterday. My take on this light is pretty much the same as Don's. The E-Bay seller (go_market) was really responsive. Ordered the light on June 1, it shipped on June 2, I received it in New Mexico on June 7. I don't have to have a light that burns holes in things @ 10 feet but this one could be a little brighter.
Bottom line is a 5 for looks & a 3 for brightness.
