hehe… I was about to say the same. Even had the same Wikipedia link ready. I was just reading up on some stuff.
I think those names are quite easy for people in the Northern Europe.
In Norway, its Åsgård.
Im sure the other lights will get cool names too. I think I remember Fasttech said they will get historic names based on mythical stuff/figures. Something along the lines with that.
On a side note. I highly recommend the tv-series Vikings! Great show. The Gods they pray to are from Norse Mythology.
Fasttech chose the Asgard name for it's mythical symbology. Asgard was chosen for the first light because they are planning on using the alphabetical order for the new light releases. This was inspired by Android releases following alphabetical order. The next light will start with "B", then "C", etc...
I’m glad to hear that, since my only bluetooth device is running CyanogenMod 7 (Android 2.3). So, maybe I can use it after all!
I’d prefer a smaller light (Convoy S3 size) for programming purposes, but I’ll probably still buy it if I can get the app to work. I’m just not sure that a thrower has as much need for the extra flexibility, since throwers are most useful on 100% output instead of more interesting modes.
With any luck, I’m hoping to give it a variety of true-strobe modes at different speeds. It would be useful, for, among other things, making a seemingly-impossible water fountain… the video works because the camera is running at 24Hz with short exposures, but the same could be done with a 24Hz strobe light in a relatively dark place. Strobe lights are fun for other things too though, and I’d love to have a ~1000 lumen one I can EDC.
I’d love to know more about how programmable the Asgard is. For example, does its programming language have any form of logical control structures and loops? Can it stay on while the power button is being pressed, for things like press-and-hold to ramp the output? Does the language have a concept of variables and mathematical operations? How much space is available for storing programs / modes? Can the user define multiple mode groups and switch between them with well-timed button presses? Is there any type of random number generator, for things like a randomly-varying strobe mode? Etc…
Sorry to jump on this sub-thread, but I can’t find fasttech’s post above…
FastTech,
What you said about “theoretically work with Android 2.1+” is good, but then, can you ensure that your developers don’t do something, or configure something, in the app that would explicitly PREVENT it from running on, say, Gingerbread? I’ve seen (and been frustrated by) too many Android apps that just won’t install on a specific version (i.e., Gingerbread) because the app developers configured the app to exclude certain versions of Android when they implemented their app.
I don’t know about others, but if I was going to buy an Asgard (and I am now seriously considering it), a lot of its value (and possible usage scenarios) would be lost to me if I couldn’t use the Android app.
I read that the default on this light is something like, low, med, high. So, does this have 3 settings available? You could program ‘many’ different light settings but only use 1 of three at any give time. Then use the app to transfer other settings to the light if u want? Is that how this will work? Sounds like fun, for a while……
I’m hoping to be able to program moonlight low medium high with memory, its just about my favourite set up, this would make this light an awesome bed side light - moonlight or very low for baby duties, high with decent throw for when things go bump in the night.
I also agree with a statement above, it would be nice to know if the 7135’s are addressable, then you could stack the one for high to gain a higher high and retain a very low low, unless I’m totally not understanding the driver set up.
Since the moonlight mode doesn’t have PWM and each 12.5% in output doesn’t have PWM, I don’t think the moonlight uses any of the AMC7135 chips but uses something else instead. Seems to me you could double stack each 7135 if you wanted to get 6A output without effecting the moonlight mode. Of course I’m just spit-balling here but it sounds logical on the surface to an electronic ignoramus like myself.
that’s kind of what I was wondering, it would be nice to keep moonlight - 12.5% of 3a - 50% of 3a - 4.5a+ for high and use an xm-l2 nw on copper that way you get moonlight low no pwm medium no pwm - high no pwm 8)
