Thanks Dr. Jones. I can’t thank you enough for your support for this community.
I really need to get set up for driver programing, this set up would cover about 95% of my driver requirements.
Thanks DrJones,
is it possible to set up just 1 (100%) mode?
Awesome, thanks so much Doc!
This is an awesome help for a LOT of people out there Dr. TY :-)
Nice selection.
I had the kaidomain clone from KD which had a star to disable memory and thought why is that not the standard?
Could you please add a description which star is #1, 2….,?
awesome work DrJones, this is a very handy resource!
Oh man, I can't find enough free time to play with this :(
DrJones,
thank you very much for your effort and for sharing it with us.
This driver was the reason for me to just buy an isp programmer and a soic clamp, finally.
I read the perfect modes thread more than once and even downloaded some files… but it’s all way above my head.
But now there’s a chance for usable results and then, who knows where curiosity might yet lead me.
Again, thank you.
BTW, the latest QLITE Rev A drivers that I got in from I-O don’t seem to have any lock bits set. I have not tried reading/re-writing the firmware on them, but it should be doable.
great drJones!!! thank you very much!!!
How do you know that it doesn’t have lock bits set if you didn’t tried reding it
I read the lock bits and the fuse bits. I didn’t try reading and re-loading the firmware (didn’t want to muck it up if it didn’t work).
If I only know how to do that I would backup genuine SW immediately (also if I had new Qlite)
so, in the name of BLF progress please do download that SW
Thank you and God bless you :bigsmile:
+1
Thanks Dr. Jones!
BTW, is there any danger in flashing the driver in the assembled flashlight (with the LED connected to driver)?
I do it all the time. Note that if the star connected to pin 5 of the processor is connected you cannot flash the firmware.
Noted, thanks!
I just wanted to take a second to thank you for this! Even though I program my own drivers, this is actually a great option for some hunting lights that I will be building for friends. This will give me the ability to provide them with 4 brightness options with no memory (when out in the woods on a dark morning, moonlight is a great mode to always start on). If later they want to add memory and get rid of moonlight, I won't need to remove the driver and reflash it.
Does this still retain the low-voltage detection?
I've had a hard time setting a moonlight mode on my drivers, especially with that high of PWM frequency. It does vary per LED type, so it was always trial and error until I got the PWM level right. We'll see how this works with an XM-L2.
