Got mine today. Like it. Only "problem" is you need to turn head pretty much open to eliminate "push flash". And head is more glossy and lighter color.
Sorry to hear that then :(… I wonder if thicker O-rings might help/work.
My 2 lights were really loose before I added the 2 O-rings, but after that they’re good. I still keep them in the boxes, and the only time I see that push flash is if I’ve only unscrewed the head slightly.
Looks like it could be a winner, would be nifty if it would hold shape to use 123s or 16340s in a pinch. Just offset the shipping by ordering more stuff
Many (larger) 1x 18650 lights have drivers with voltage range of 2.8-6V which permit use of 2x CR123A…. PDs, 1st responders, and military usually use CR123 primaries instead of 18650 li-ions.
1x 18650 or 2x 16340 (2.8-8.4V) capable drivers are not as common… Which makes a lot of sense to me. If you are going li-ion instead of primary, best to use the larger 18650s with superior run time. Only advantage of 2x 16340 is that it may be brighter (and hotter), but that depends on what kind of regulation is used. And run time will suck.
That said…. given the heat issues this tiny light has, anything over 4.2v would not be wise IMO. I see no reason to fit a driver that exceeds this.
I did some ceiling bounce lumen estimates on my (NW) DQG18650. There were measurents before from _the_ and relic38, and those were undoubtly better performed than mine, but here are the numbers anyway, actually consistent with their numbers and somewhere in between:
low: 12.5 lumens
med: 157 lumens
high: initially 470 lumen, within a second already 420 lumen, settling after two minutes at 335 lumens and from there a very slow decline.
What I believe is happening on high setting is the following: the very rapid decrease within the second is actually pointing at a unusual high thermal resistance very close the led, directly where it sits on the board, then the still fast decline points at a lot of thermal resistance anywhere through the board to the body. The very slow decline leftover after two minutes is the limited surface area from body to air, so that the body is still warming up slowly.
Design-wise just the limited surface area of the body is not avoidable (it is already made of aluminium and we want this light small) and it is not a big problem anyway. The other thermal issues can be avoided largely by a different design (such as using a small pill anyway with separate led board and driver, it will cost a few mm extra). It made me wonder wether the board the driver is made on and where the led sits on is a metal core one? I noticed from the DQGAAA that that is not the case, and my guess is that it is the same here so that the heat path directly near the led is only through the electrical traces and not through the board at all, which may also be the reason to choose for fujiking the board behind the alu divider in the head.
Actually i can answer the question myself, and with my own picture of the driver ( #574 ) : the driver board contains a large amount of via's and I guess that would be impossible with a metal core one
Going from 470 to 335 lumens means a decline to 71% of initial output. If you look at Cree's xml data sheet about junction temp/luminous flux that would mean a junction temperature of about 155 deg. C ! Awfully close to the melting point of solder, bad for the led anyway. I hope my measurements were lousy and this is not true .
I don't think it is voltage sag, I used a Efest 18650 IMR battery fully loaded, at 2.0A in the first minutes (not seconds) the voltage drop is 0.3V the most, the voltage stays very near to 4V. It will affect output but nothing near to 30%. And I could repeat the same drastic output decline after cooling down for half an hour without recharging the battery.
