BBC taken from Tim Allen. Last year I was playing around with making dedicated heat sinks for 7135’s and came up with this And since then I’ve been itching to use the idea in a mod. Layers of copper sheet separated by thin copper wire rings. There have been some great custom milled lights done lately where the heat sink is also part of the exterior of the light which seems a very good idea to me.
So I cut a strip of copper sheet(~.5mm thickness) and drilled a series of holes then used a 7/8” hole saw to make some copper washers.
Then I flattened them out again between two washers in the vise. They don’t need to be perfectly centered as there is extra but the three on top didn’t pass QC.
I
p. Next I wrapped some solid copper wire around a slightly smaller pipe than my intended then shifted it to the actual copper tube to cut the spiral into rings.
Then I cut 2 brass sleeves that fit over the copper tube ends and assembled it with flux, clamped it in the vise and soldered it. After filing the outer edges even (chucked it in the drill press and used a sanding block on the spinning part) it came out like this. !{width:100%}http://i1166.photobucket.com/albums/q619/Rufusbduck/C5B917EF-B392-4132-A... 3DDD749_zpsdf0d2977.jpg!
It still needs a bit more sanding before a final polish but I’m very pleased that it came out so even with nice narrow spacing(the fins take up 5mm of the overall 16mm length). It is destined for a semi-shorty custom AAA Minimag and there will be some other new(to me) mods in this light as well. Stay tuned(or not as it could be awhile).
05/07/13
p. This driver is much like the one for my last solitaire mod. The 7135 chips are removed from the board and AA’d together into a stack (380mA bin) but this time after cutting down the board I ground the bottom of the board completely smooth and a bit thinner as well and made a new copper contact plate tinned on both sides. Traces no longer needed were scraped off.
The holes you see in the bottom of the board are where the new ground wires will run for the mcu, capacitor, and low voltage sense resitor. Also needed are paths through the board for Vdd, Vin, and Led-. The contact plate was adhered to the bottom of the board with Fujik, the holes were continued through the copper and ground wires soldered in place. Then the stack of 7135’s was reflowed in place.
p. Other side of driver. Hole on the left is for led-. There are actually two holes side by side on the right. One for Vin/led+ and the other connects to the remains of the Vdd trace. The very small ground wire connections disappear in the reflowed solder. Remember, this board once measure 17mm Dia and is now 12mm Dia. Once those wires are added, this side will be potted into a cylinder with a positive contact pad over the chips leaving the rim of the plate exposed to make contact with the deanodized battery tube.
The head will be cut at the knurled section and is bored to fit the brass sleeve so that when reassembled the copper fins will appear in the middle of the head.
I’m sure by now some are wondering“BUT WHY?” and for them I have no answer. All I can offer is that by observing OL, Match, and JohnnyMac, I have become hooked on small Maglite mods with classic stage seven flashaholic symptoms. The excellent work done by those members blessed with a lathe inspires the plagiarist in me. Add some alchohol and bar knapkins and you get one of my creations. “Can I” gets more play than “should I”. I hope you enjoy reading these threads as much as do those of others here.
5/11/13
Here’s how the fins look in the pewter AAA Minimag head.
5/12
Tested the driver today, 1.11A on high, .345A med, .061A low. Close enough to 1.14A for 3 × 380mA chips. I used long skinny leads on dmm.
5/17
One of the design goals was to make this light as short as possible and to that end I ordered some of the short size “f” springs from IOS. Diddling the tail cap entailed cutting both ends off, drilling the center bore out to 1/4”, pressing in a tinned section of copper tubing, and soldering copper bits to it.
p. Not much left after the cuts. This how it looks with the copper pressed into the shortened piece.
And here with the plates and spring added.
5/18
Now, where do I cut this thing?
That worked ok. About the same size as a Solitaire but brighter.
Just for fun I made some mini fins(ID 11.1mm, OD 13.1mm, thickness .44mm) to dress up the cuts in the tube and to act as stops for the clip. The tail cap also is bigger than the tube(13.2mm vs 12.7mm). Overall length when “on”, 82.5mm.
The Sinkpad is reflowed to the pill and the driver potted in. I’m using the light as a jig to make sure they align properly and will have to wait until I get home again to fire it up. It’s not a flame thrower, just another 10440 Minimag.
5/25
Here it is. In the previous pic the tube was assembled but not glued with JB Weld.
Here are a few pics of the parts before assembly. I made a particular effort to file the knurling so that section ends at the
apex or midpoint of the diamonds at both ends. The brass sleeve is what holds it all together and maintains circuit continuity. The copper rings aren’t necessary to hide the joints which fit nicely without any pressure but I like the way they look. A direct copy of OL’s work.
Some other small changes to improve the light. I cut, filed, and sanded a lip on the front of the optic to allow it to project about 1 mm through the bezel. This, along with relieving the backside(interior) of the bezel allows the optic to move forward even more. These combine to give more thread engagement for the head, some of which was lost by adding a driver.
Lastly, to snug in the optic and improve its water resistance I put a 5/8” OD o-ring between the optic and the head and filed the bezel end of the head piece so that there is a nice compression fit on the o-ring.
A fully charged efest 10440 pulls 60 mA on low, 350 mA on med, and 1.11A on high so the driver survived the build.
6/03
After a brief stopover with Texaspyro to measure lumen output and the thermal effect of the fins to whom I owe a debt of gratitude for this as well as shipping on the light, it has now reached its home. Someone far more capable than I has posted a few glam shots at the end of this thread for you to see. Even working on this light under magnification I never saw it look this good. Dale can shoot!
Scott
i don’t think it was your intent (since I’m a little confused about what you’re making)…but you just gave me an idea for giving p60 dropins a thermal path to the light body
____________________
Girls can shoot!
It will be more obvious when it is installed in the head. There was a class in descriptive English in the 7th grade and though otherwise I was a good student, in that class I was humbled with a D. :~
Scott
Nice job Mr bduck. A couple off things. You cannot drill 20 thou sheet without sandwiching it betweem something else. How did you drill this. Secondly, you have far to much spare time on your hands. Thirdly what you have done is fantastic.
djozz quotes, "it came with chinese lettering that is chinese to me".
I’m very pleased at the outcome too and am hopeful to see it closer in the near future!
Great work there, don’t know how you do it, but you do it well for sure. Staying tuned for the next chapter…
MRsDNF, your right. I sandwiched the strip between two blocks of wood and still had to trim the edges and reflatten in a large vise. No extra time, I did not go to sleep last night but did this instead. And thank you. My ideas quite often don’t work but it’s nice when they do.
p.Dale, yup, I hope you get to see it up close in some future, near or otherwise.
Scott
Take some 3/4" copper pipe, cut off a ring about .325" long. Slit it so it makes a 'C' shape, and spread it out a bit so it's a tight fit into the light body. Trial fit it and file it down as needed to a height that keeps the bezel/head (or whatever, depending on the design) just shy of seating completely, so that the reflector is clamped down tight between the copper spacer and the lens.
If you swap out drop-ins often, take all your reflectors and sand the bases down so that the OAL is the same on all of them, then the fit will be the same no matter which one you stick in. That also lets you put a nice wide flat surface on the base of the reflector to mate with the copper spacer.
Plus, you also get to throw away all those annoying outer springs as you get a much better ground path.
tl;dr version:
Nicely done, RBD! You sure do come up with some great ideas and some novel ways to do them.
The Flashlight Forum (TFF)
The Vaping Forum (TVF)
https://docs.google.com/spreadsheet/ccc?key=0As
Wow. Looks like something on a Buck Rogers Atomic Disintegrator raygun 8)
That looks better than quite a few mods done on a lathe.
Well done, sir !
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
Very clever.
Now get some sleep!
I like copper
I’m only commenting again because I’m still a little amazed at the work that has gone into this and how well its turned out. For those that dont work with metal this is a work off torture and love which may not be apparent. Again nice work Mr duck.
Amazes me what some people can do with proper equipment, and what others manage to do even without! Sheer genius on a whole nutha level!
Keep up the good work RBD, I’ll take plenty of pictures for you when you’re done…no charge!
Update in op.
Scott
That driver is really coming along, as is the work with the copper fins. This is gonna be totally radical!
Love it!
I’m still in awe off your heatsink and driver. That heatsink is a serious piece off art and l cant comprehend how you have made it let alone it looking as perfect as it does.
I can’t wait to see how this thing fits together.
That is some excellent hand work there. People just don't know how much trouble it is to do work like that until they try it themselves. It came out great! Can't wait till the whole light is finished.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
I still can’t believe that you can manipulate the driver that way! Driver Magic, that’s what it is! And those fins in the pewter minimag, wow, stunning! Good job, really good work there.
Great work, very nice outputs! That should work splendidly with the XP-G2. And “hot” enough to see how those copper fins work!
What a beautiful heat sink. It is like you hit every aspect and ratio dead on as far as good looks go. I cannot believe how straight and even those line came out. Well done.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
I do not think that the BLF-community ben
So how’s the build going? Fins are ins, driver is bad to the bone, time to cut up the battery tube? Will it stay under 100mm as a twisty? Neeeeeeeed moooooore !
By the way, the Captcha is trippin out down below, reversing the normal question and asking for a wrong answer!
Glad I was awake, might have tripped me up. hahaha
It’s looking like sub 90mm if I diddle the tailcap. It’s so top heavy I don’t think it’s worth bothering to keep tail standing as an option but hmmm…
Scott
I wouldn’t think tail standing would be an issue with a light so small. Certainly not for me. Besides, I’m betting a bit of Sugru would make a nice stand.
AA a small thin strong rare earth magnet to the end and it will tail stand on anything with iron in it. lol
Diddle the tailcap, I always wanted a diddled mini mag. 8)
Edit: Ooh Ooh, a shiny tailed diddled finned mini mag!
RufusBDuck works in small
But his projects stand very tall
His brass rings and fins
Are the mods that are in
And his drivers are loved by us all.
That’s a SERIOUSLY diddled tail cap! And gorgeous! And will match up perfectly with the fins up top! Love it! Brilliant thinking Scott, just simply brilliant!
So now is it prudent to consider nuclear cell research? This things gonna be RBD Small for sure!
Impressive, Like No Other!
Your in trouble on 3 accounts Mr bduck.
1. When you put new pictures in can you please let us know. I read your post yesterday and skimmed over it not knowing what I’d missed out on. :_(
2. I know your working in miniaturization and l find it hard to comprehend how small these items are. If you dont own a ruler I will purchase one for you. Dont be shy. I dont know what a liberty coin is or how big it is
3. I’ve been distracted by the Mastermind and cant remember what the 3rd thing was. You may be lucky.
I keep telling you how stunning your work is and l do not apologize for this. I’m also not on the ducks pay roll for giving him compliments. This is inspirational work there buddy and I love it. I cannot imagine how long that driver has taken to build but l’m guessing it isn’t a five minute job just like anything else you have done on this light. I can only picture this as a work off dedication.
The duck must be mad.
That’s a dime MRsDNF, 10cents, our smallest coin. Don’t ask me, I’ve never figured that one out either.
Roughly 17mm across for you blokes across the big water. Or about what a copper pill costs.
I edit the title when I add new stuff/pics. If I start with a stock part, take it for granted that modded it will be either smaller or a different shape but I’ll try to remember to include a ruler or measurements with pics. Thanks for the reminder Mr Moose.
I like the way this one is turning out. Definitely some keeper ideas. The fins alone should really help with an XML AA shorty as there’s much more volume available.
Scott
Couldn’t you start with a copper bar and make the fins out of that, insert it the same way? Instead of all the brass sleeves and rings and washers, seems like that’s more time consuming than just cutting a copper bar down and boring it out. Then you’d have more copper mass with more heat removal properties and you could leave the base for the emitter in the bar for a one-piece built in “pill”. Cup the bottom for the driver and you’re done. Well, maybe not that easy but you probably see my point.
Can’t chuck that diameter copper bar in your drill press? No problem, drill it and tap it put a bolt in it and chuck the bolt. Let that be the driver end or emitter end, either way, when everything else is to your liking ream out the tapped hole to accept the driver/emitter whichever you choose. Just a thought.
In the meantime, I’m really loving the result of your creativity! Checking my Efest IMR10440’s to be sure they’re charged up and ready!
I’m not sure if it’s possible to machine fins as thin as these but I know for a fact that my drill press method is limited to a fat gap(~1.5mm) and that just wouldn’t look right. With this method, the spacing is controlled by the thickness of the wire spacers and though tedious is straightforward and repeatable. The cosmetic drawback is that the joint in the wire spacers is visible. When you get it your photography will expose all the defects not visible in my poor iPhone pics.
Scott
But when you see pics I take of it, it will be flawless!
