DQG 18650 EDC--World's Smallest 18650 Flashlight
698 posts / 0 new
Haterade
Last seen: 7 years 2 hours ago
Wow that sure is not black. The difference with my titanium one is not nearly that dramatic. Actually looks kind of cool… But I understand your disappointment.
I agree with your overall critique relic. Forgot to mention mine did not have either body o-ring installed. I put on both, along with fixing the head arrangement. I can forgive these quibbles on a pre-order first run unit, but I think you have a point on pricing. $35 might be a tad high.
I like copper
relic38
relic38's picture
Last seen: 5 years 1 month ago
If the whole light was that colour, I think I would be OK with it. It’s a little less obvious in hand, The shot seems to bring it out a bit more.
In any case, I’m going to ask Ric for a replacement head that is black.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
Haterade
Or a green tail? Silly
I like copper
PewPew
Last seen: 9 years 8 months ago
Got mine today, Ti color NW tint. Head ano is just a tiny tad lighter, tint is about on par with the neutral on my EagTacs. Did all the same o ring and lubing business as everyone.
For my first budget light, I’m impressed, would buy it again. Was a little worried that my protected 3100mah wouldn’t fit but they do Smile
Haterade
Glad to hear it. Enjoy Smile
I like copper
PewPew
Ok, found a bad thing. That tail spring is bad, really bad, but luckily it was easy enough to remove and stretch out some, my longer cells smooshed it down so then the unprotected ones turned it into a DQG strobe…
Time to find a locally stocked feasible replacement, not waiting for another month of Sundays to get a spring…
ohaya
Last seen: 1 year 1 month ago
PewPew wrote:
Ok, found a bad thing. That tail spring is bad, really bad, but luckily it was easy enough to remove and stretch out some, my longer cells smooshed it down so then the unprotected ones turned it into a DQG strobe… Time to find a locally stocked feasible replacement, not waiting for another month of Sundays to get a spring…
Hi,
Are you looking for a spring CONUS?
Would this work for you?
http://www.lighthound.com/HDS-EDC-LED-Flashlight-Spring-ONLY-for-2-x-123-Battery-Case-or-1-x-17670-Battery-Case_p_615.html
Jim
picrthis
picrthis's picture
Last seen: 2 weeks 17 hours ago
ohaya wrote:
Hi,
Jim
.15 for the spring and $3 for shipping Silly
Fenix TK12, TK15, TK21-U2, TK61, TK75 Olight M20S, M21<span style="color: #0000ff;"
M3TAL_L0RD
M3TAL_L0RD's picture
Last seen: 1 month 4 weeks ago
Got mine today. Like it. Only "problem" is you need to turn head pretty much open to eliminate "push flash". And head is more glossy and lighter color.
djozz
djozz's picture
Last seen: 6 days 13 hours ago
relic38 wrote:
I figured out a way to get a decent shot of the head colour. Anyone else notice this on their black DQG?
No, mine came out nice 'n matt black:
But I really dig the head colour of your light, I agree in that would it be nice to have a matching tail Cool .
Haterade
M3TAL_L0RD wrote:
Got mine today. Like it. Only “problem” is you need to turn head pretty much open to eliminate “push flash”. And head is more glossy and lighter color.
True. Many twisties, especially on the budget end of things, have this issue. It can be annoying.
Here’s a few pics of mine:
Kind of hard to show the difference in finish, but you get the idea.
I like the flat black on yours djozz. Goes great with relics green head lol
I like copper
ohaya
Do you have (did you put) 2 O-rings on the threads on the body?
One of mine had zero O-rings there, and the other had only 1. After I made sure there were two O-rings, that “push flash” problem is much better.
M3TAL_L0RD
ohaya wrote:
Do you have (did you put) 2 O-rings on the threads on the body? One of mine had zero O-rings there, and the other had only 1. After I made sure there were two O-rings, that "push flash" problem is much better.
Yes, I did put 2 black o-rings. And there is still 1 extra white and black one.
Still needs 3/4 turn to eliminate "push flash"
ohaya
M3TAL_L0RD wrote:
ohaya wrote:
Do you have (did you put) 2 O-rings on the threads on the body? One of mine had zero O-rings there, and the other had only 1. After I made sure there were two O-rings, that “push flash” problem is much better.
Still needs 3/4 turn to eliminate “push flash”
Sorry to hear that then :(.. I wonder if thicker O-rings might help/work.
My 2 lights were really loose before I added the 2 O-rings, but after that they’re good. I still keep them in the boxes, and the only time I see that push flash is if I’ve only unscrewed the head slightly.
ohaya
picrthis wrote:
ohaya wrote:
Hi,
Jim
If that spring would work, I wonder if you called them and asked if they could reduce the shipping for 1-2 springs? $3 seems steep (understatement Smile )…
Haterade
Yes I agree. It can be made to flash, but mine is not really worse than other similar twisties including my thrunite neutron 1C, for example.
edit: OK scratch that. Tried again. No flash. Must’ve been before I added the two black o-rings to the body. No flashing by pressing now.
Whoops. Tried again and it sure does flash when pressing on the head. Dangit. I’m not messing with it anymore Silly
I like copper
PewPew
Looks like it could be a winner, would be nifty if it would hold shape to use 123s or 16340s in a pinch. Just offset the shipping by ordering more stuff Smile
ohaya
Do we actually know the voltage range for this? I don’t remember seeing that. I wonder if it could take 2×16340, would it be brighter?
EDIT: I am NOT suggesting anyone try this until we know for sure. I’ve PM’ed RIC.
PewPew
Pretty sure there’s a post higher up about someone who tried two 123s and killed it, the driver is made for just one li-ion battery.
ohaya
I kind of thought that, but it’s hard to go through 600+ messages. Wish that BLF had a thread search.
Haterade
could use 1 cr123a and a spacer in a pinch
I like copper
picrthis
picrthis's picture
I think the Title of this very thread ought to be a clue Shocked
World’s Smallest 18650 Flashlight
Haterade
Many (larger) 1× 18650 lights have drivers with voltage range of 2.8-6V which permit use of 2x CR123A…. PDs, 1st responders, and military usually use CR123 primaries instead of 18650 li-ions.
1× 18650 or 2× 16340 (2.8-8.4V) capable drivers are not as common… Which makes a lot of sense to me. If you are going li-ion instead of primary, best to use the larger 18650s with superior run time. Only advantage of 2× 16340 is that it may be brighter (and hotter), but that depends on what kind of regulation is used. And run time will suck.
That said…. given the heat issues this tiny light has, anything over 4.2v would not be wise IMO. I see no reason to fit a driver that exceeds this.
I like copper
djozz
djozz's picture
I did some ceiling bounce lumen estimates on my (NW) DQG18650. There were measurents before from _the_ and relic38, and those were undoubtly better performed than mine, but here are the numbers anyway, actually consistent with their numbers and somewhere in between:
low: 12.5 lumens
med: 157 lumens
high: initially 470 lumen, within a second already 420 lumen, settling after two minutes at 335 lumens and from there a very slow decline.
What I believe is happening on high setting is the following: the very rapid decrease within the second is actually pointing at a unusual high thermal resistance very close the led, directly where it sits on the board, then the still fast decline points at a lot of thermal resistance anywhere through the board to the body. The very slow decline leftover after two minutes is the limited surface area from body to air, so that the body is still warming up slowly.
Design-wise just the limited surface area of the body is not avoidable (it is already made of aluminium and we want this light small) and it is not a big problem anyway. The other thermal issues can be avoided largely by a different design (such as using a small pill anyway with separate led board and driver, it will cost a few mm extra). It made me wonder wether the board the driver is made on and where the led sits on is a metal core one? I noticed from the DQGAAA that that is not the case, and my guess is that it is the same here so that the heat path directly near the led is only through the electrical traces and not through the board at all, which may also be the reason to choose for fujiking the board behind the alu divider in the head.
Any comment on my wandering thoughts?
djozz
djozz's picture
Actually i can answer the question myself, and with my own picture of the driver ( #574 ) : the driver board contains a large amount of via's and I guess that would be impossible with a metal core one
djozz
djozz's picture
commenting on my own posts, I must like myself Laughing
Going from 470 to 335 lumens means a decline to 71% of initial output. If you look at Cree's xml data sheet about junction temp/luminous flux that would mean a junction temperature of about 155 deg. C ! Awfully close to the melting point of solder, bad for the led anyway. I hope my measurements were lousy and this is not true Surprised.
djozz
djozz's picture
I saw that post Bort!
I don't think it is voltage sag, I used a Efest 18650 IMR battery fully loaded, at 2.0A in the first minutes (not seconds) the voltage drop is 0.3V the most, the voltage stays very near to 4V. It will affect output but nothing near to 30%. And I could repeat the same drastic output decline after cooling down for half an hour without recharging the battery.
Haterade
I think you’re on to something djozzy. There’s not much to the head.
How could this be modified/improved? Is there space to do anything?
I like copper
Bort
Bort's picture
Last seen: 4 min 31 sec ago
I don’t think it is voltage sag, I used a Efest 18650 IMR battery fully loaded, at 2.0A in the first minutes (not seconds) the voltage drop is 0.3V the most, the voltage stays very near to 4V. It will affect output but nothing near to 30%. And I could repeat the same drastic output decline after cooling down for half an hour without recharging the battery.
i reread your post and revised my thoughts but you were too quick
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
djozz
djozz's picture
:bigsmile:
:bigsmile:
