Going to send Ric a PM as well, but mine just turned into a single mode on low. Tried two other batteries, something kind of smells weird inside the head also.
That’s something that sounds kind of funny coming from a user whose username is “PewPew” :)… Sorry, I couldn’t really resist :(…
Seriously though, when you say “kind of smells weird”, do you mean like a burnt smell or something like that? Maybe something got shorted, which might account for the low mode?
Yeah, it’s a burnt electronic smell. Almost like when I get to killing old speakers or abusing subs, just much less potent being on a smaller scale I guess.
What’s the estimated low run time on this thing? Might as well make the best of the situation, ~18 lumes off an 18650 should last quite some time and be a perfectly usable amount of light for most things when the sun isn’t out.
Perhaps I’ll try taking it apart to see about changing drivers and stuff if a new one can’t be sent out. Also, not using it does seem like a good idea, don’t need it catching fire or something crazy.
The battery you use really does make a difference. I can get mine to work with a few types but it only works perfectly using shorter batteries. I find my protected pano 3100 is fine, green battery not double wrapped.
FYI, I had PM’ed RIC, about the voltage and battery specs, and he confirmed that 2x16340 does/wll NOT work for these lights. He said it would damage these lights. He didn’t provide a specific voltage range.
I know that most have assumed this, but again, FYI…
Yeah its a pre-order! Got a number but singpost cant track it, nore can the swedish mail! Never lost a light in the mail! Have to send Ric a hollar i guess…
- If you have an Android tablet or phone, try an app called “TrackChecker”. It sometimes can dig out information that the USPS.com (for instance) doesn’t/isn’t able to.
I’ll try after dinner to pull it apart without tearing anything up. Ric is sending me out a new driver+emitter so going to have to learn pulling it apart anyway.
Once apart I’ll give it a probing with my DMM.
