but these noctigons are two for the price of one sinkpad. and with better thermal design, it almost makes me wonder why anyone would purchase a sinkpad again
not saying toss your sinkpad and buy the noctigon, but just makes sense for future purchases
Exactly. Makes more sense for future purchase since they are cheaper and “better”.
However, cost aside, both will function with relatively little difference. I think the analogy of 2.6A vs 3.0A is a flawed comparison. There is a noticeable difference there.
I was trying to say let's not ignore a small difference (2Celsius), mostly thinking on the number itself 2.6 vs 3, not the current itself 2.6A 3A. I was ironic in that post. I actually like to get the best out of everything, like AR coated lens even if I gain only 5% more light transmission, that 5% is not a standard of course, quality of the AR or single and double sided ca make a difference in gains, or even poor uncoated original can make a higher percentage gain.
I also like the fact that the noctigon is easily available, and a good price, but the gold will reduce performance slightly, i’m not sure by how much though but i do hope its negligible, but it is possible the sinkpad may have a slight advantage being all copper, but i still agree that real world performance should be comparable between the two.
the bottom is also gold plated, and the thermal analysis didn’t take into account the gold portion, i assume it will only make a degree or two difference, but so does the divet in the sinkpad
Didn’t notice that. Good eye.
Though if people are worried about that, they can polish the gold plating off much easier than lapping that divot out.
But if I could get two sinkpads for the price of one noctigon, I would be going for the sinkpad.
One thing I disliked on the SinkPADs I got is the thickness of the electrical connections. They could do them very wide but instead they make them just these tiny copper layer lines.
Now look at Noctigon and see how wide the copper electrical connection is from the pads to the emitter.
I have to say just that would make me prefer the Noctigons if the price and other things were the same as SinkPAD.
Sure you don’t need wide electrical connection, and they do safe some little cash on material by having it thin but it does not hurt to have it nice and wide especially when XM-L is 3A emitter, some people push it even higher and reducing all resistances is a nice thing to do with high loads.
Gold plating is a nice touch too, it does not tarnish over time. Especially if you touched it just once the pure copper will tarnish fast. At least I can see that on my SinkPADs stored in a sealed bag that I’ve touched and some didn’t even have to, it does tarnish. Especially if you work with pure copper you will notice it, otherwise you might just say hey that is clean, for quite some time until starts to get darker and browny and then green haha.
How significant is the difference in thickness between Noctigon and Sinkpad?
Sinkpads seem to be substantially thicker? Will this make them better able to absorb and transfer heat? Especially considering the star is going to be sitting inside an aluminum flashlight.
