Solarforce S2200 MT-G2
Bookcase on Medium or use High and 1/8000 of a second? :slight_smile:
Can anyone tell me if this A0009 serial number is truly the 9th one in circulation?
Bummer. Was really hoping they had fixed that. Don’t know if I can plunk down this kind of money for a light with that on it. :frowning:
How’s the low?
I was thinking about your comment about throw, and that the throw would be better with an SMO… that’s all :)…
MTG2 in the S1100 smooth reflector has a two-stage hotspot, I guess you could call it, on a white wall, but in actual use it's not noticeable. It was like this with the XML too just with the center spot about half the size. The main center spot is still very sharp and well defined.
Anybody else notice how far the MTG2 is set back from the inside of the reflector, like we talked about in other threads? It definitely does NOT like to be shoved way out into the reflector like an XML does, that's for sure.
Ok, don’t know if this helps or not but here’s some comparison shots. The camera was set on auto this time to keep everything in perspective so that only the color of the light would be the issue. All pics on the right are the same pic, the S2200 on Hi. The shots on the left are, from the top, the L2P M3 w/ XM-L U2, the L2P EDC+ Triple XP-G2 (I think 5700K), the HD2010 w/XM-L2 T6 @ 5000K and the L2P EDC+ Triple Nichia 219 @ 4700K. Shot in a dark room with only the flashlights for light.
The color stays good from Hi to Lo. The 3 shots below start on Hi, then Med, then Lo. The shot on hi is 1/160 f6.3 ISO400, med is 1/100 f5.0 ISO400 and lo is 1/20 f4.0 ISO400
Is that an incredible LED, or what? :love: Now do you see how hard it is to put into words how much difference there is from a typical XML light?
Can you do a wall shot that shows the beam pattern? Just curious how much difference there is between the two reflectors.
White styrofoam ceiling tile, one square foot in measurement. Tail standing on the floor in a room that’s 8’6” high.
Remember when a light that made 100 lumens was kick a$$? That’s low on this one! 800 lumens is screaming (well, not long ago it was) in a P60 drop-in, how about Med here? :slight_smile:
Yeah, gotta love it.
Enjoy! Gotta run, wife’s surgery is at 8AM, we’ve gotta be there early. I’ll be out for a couple days with her while she’s in the hospital. Will try to check in Wed some time.
Hmm, looks good. The MT-G2 is a huge emitter as compared to the XM-L, is it Cree’s offer to the Luminus/Phlatlight SST90 possibly ? or just a differnet class of chip ?
It's a multi-die emitter, so it's not like those you mentioned.
thanks for all the info - I might have to pull the trigger on one of these bad boys!
How is the out put on extended runtimes? does it stay in regulation for the whole run?
Sure does... or, there's nothing to indicate it doesn't. 3S even completely flat is still well above the LED's Vf so if the cells are capable of providing enough current at that point, it'll stay at full output. The 'low batt' warning, I don't know what it trips at under load, but after the cells are removed from the light they're at 3.3v/cell. That 1+hr run time is the point just where the indicator turns from green to red, which still leaves a good reserve before it's actually out of juice. I've never run mine past that so I don't know what it does if you don't switch it off when it goes red (whether it shifts to a lower mode, or shuts down completely).
My hybrid version does almost exactly the same tailcap numbers as measured by DBCstm, so I think it's pretty clear the driver circuitry isn't changed from the S1100. Only change being the different UI with hidden blinkies which doesn't affect the output.
thanks - it looks like this one might be finding a home in my collection - might wait for a full review just to be safe though
i almost bought the 7g10, but i like the solar force much better
edit: i guess i have some time to decided… everyone at solarforce flashlight sales is on holiday for a bit
Does this have a thermal or timer based step down when run on high continously?
No, none whatsoever. It doesn't even downshift when the batt indicator turns red.
I was wondering why I hadnt gotten a shipment notification from solarforce flashlight sales yet… :weary:
I'm in the same boat.
Just over a week before they get processed and shipped. Seems like a light worth waiting for.
