Quick quesion: is (or are) there any conditions( s ) one could utilize to program a function that informs the user that Vbatt has dropped or will imminently drop below the point needed for regulation (e.g. very quick and subtle double PWM blink back and forth from 100 down to 50% or similar)?
It’s superfluous but as a flashie I’ve always wanted that feature. Done properly I think one should have to be looking for it in order to see such a notification.
I was avoiding SRK because it's stupid modes but with this driver, situation would change for sure so, if I ever manage to get SRK for 15$ (or at least under 20$) I will definitivly buy this driver.
What a great idea texaspyro! Its nice to see that youre making some positive headway on your driver. If you can do these for under $20, please include me for at least 2. This would make a very good light a truly exceptional one. Good luck to you!
I just put in some hooks for the user to program their desired modes… if the button is pressed when power is applied to the light, it will erase the current configuration to the default and enter programming mode (indicated by three blinks). You then click through the default mode list to the desired mode and hold the button down for a second to store the mode. Repeat the mode selections for the modes you want then power down the light (loosen the tailcap) to exit programming mode.
Im also try to do pcb layout 7135 based driver (used Tiny13A instead of 85)
sadly pcb manufacturing company here quoted me a cost which was higher than price of SRK
Try OSHPARK.COM and Seeedstudio’s Fusion PC board services. OSHPARK will make you three boards for $5 a square inch ($1.67 per square inch per board). Price includes shipping(at least in the US).
Seedstudio is a bit less, but you need to buy more buy more boards.
You can set up the mode list in any order that you want (OK, the first mode is always set to OFF) and include any of the standard levels (currently moon, 10, 25, 50, 100) and patterns. The mode list is stored in EEPROM and is maintained between battery changes.
Unknown at this time… AMC7135 chips require a certain minimum pulse width to turn on. At 15 kHz PWM, this is around 1.5-2% of the full PWM range. That produces a very dim output. Couple that with the capacitive load of driving 24 chips and you may need to boost the PWM some more to get the LEDs to light up. The minimum setting might vary depending up the LEDs and AMC7135 chips that are used. A setting that just lights one light could put 50 lumens out another one.
Once you get the width wide enough to turn on the LEDs, each PWM step should increase the output around 10-12 lumens.
I was tempted to ask you for you a low moon mode, but it might be better to handle this with the ramping mode you're already planning on doing. It could start ramping at crazy low levels that might just barely light up one LED. That would be good enough if there's mode memory or if it's user programmable. Hell, I don't think I'd even care if you share the code. It'd finally motivate me to buy the tools to program the chips, and I could tweak your program to suit my needs perfectly. You're putting in a lot of special code though, so I would understand if you wanted to keep it to yourself.
@texaspyro: How about turning on single LED for moonmode if there are individually addressed.
I have few to add
-Leads for MCU for easy programming if the real estate permits.
-Individually addressed AMC7135(guess it requires more than a double layer PCB and a different MCU)
-Individually addressed LED modes(also used for status).
I also wanted to suggest individually addressed LEDs like niteye E30-E40 has for low modes if it is poseable and leads from mcu for one smd led that could be mounted near the switch and used as status indicator led like with P25/TM26/EA4 etc.
But, I don't get the idea of ultra low "moon" modes, those are just unusable for me, minimal amount of lumens that I find usable are about 80-100lm, for anything less than that you could just use:
Nice work. Looks like it will be a real winner. I hoping that you’ll be selling these boards and and MCU’s. Wishing you the best of success on this endeavor.
