sounds like some sort of pwm… i only ask because im sensitive to pwm… i sold my terminator and skyray king because of the low modes having low frequency pwm (around 400-800hz) it makes me nauseous and very dizzy after 2-3 mins
the higher frequencies are ok though… i never have issues with 7135 based drivers (4khz pwm) or nitecore ea4 (high frequency pwm)
I have tried several 7135 based boards with the shower method and this is much tighter than that, so you should be fine with this one. Just don’t use the Strobe, it’s disorienting to me and I’m never bothered by that! A few seconds of it on the wall and everything gets weird, so it’s quite potent!
ok - it looks like this light is 99% a go… might wait to see what the niwalker is like - but its probably too expensive for me… heck $140 for this thing is pushing it
I took a couple of shots as well as some video from the car, a 2012 Ford Escape. With the camera on a tripod out the moonroof and the light handheld, here’s a couple of shots of the S2200 overpowering the High Beams of the car.
I’ll try to figure out how to show video tomorrow. Amazing light, simply amazing.
I’m not sure if you get cold nights in Texas, but would you be able test to see if the inside of the lense mists up when switched on in a cold environment?
Most of my high powered lights do this, more so the larger the lense is. But some don’t, due to being sealed in a low humidity environment or some sort of lense coating I assume. It can significantly affect the beam though so it’s quite a big deal for me.
Dude why're you asking questions you already know the answer to? Just buy the thing already! :party: It may not have some of the whiz-bang gimmicks of the others, but what it does, it does correctly. And it's built like a tank. I think it's pretty clear all the alternatives have pretty serious design flaws, or QC issues. Or both.
Current at the emitter (NOT tailcap) stays at 3.28-3.31A from switch on with fresh cells to the time the battery indicator turns red.
Our 2012 Escape is the last of the old body style. They came out with the Euro version in 2013. Ours was actually made in April of 2012, does that help? I thought it had pretty decent headlights, but they are obviously more the orange color we’re used to from car headlights and not as powerful as I’d thought. (research says Hi beams are ~1100 lumens each.)
Cold nights? In Texas? Oh that’s rich! We made it to 24ºC overnight, I get chilly at that temp but don’t think that counts for what you’re talking about. I could stick it in the deep freeze at 0ºF and see what happens? With the lens sealed, it shouldn’t mist up inside. And yes, I can certainly see how that would be a problem in colder climes.
Sweet answer comfychair, and nice figures on emitter amperage! I did not know that, and now see where they get 2200 lumens from! Thanks
Uploaded video last night but Flickr bonked it. Trying again as we speak. Should be able to get that posted within the hour if all goes well. No accustomed to linking or posting video.
S2200 is in the deep freeze at 0º F (–17.8C), planning on leaving it there for 15 minutes, then we’ll see. Hope the lens doesn’t shatter when the heat from that humongo emitter kicks in! Yeah, it puts a lot of heat out front, good handwarmer if it’s cold out.
