There is no comparison with XML lights, it's just too different in every way I can think of.
I've posted a pic similar to this somewhere else, this is the same thing but with the white balance setting that more closely matches the actual colors. Left is a de-domed cool white XPG2 in a smooth p60 reflector (on high), right is the S1100/MTG2 hybrid (on medium). So don't let anybody tell you the MTG2 can't put out a clean, tight beam. It's not as tight as the XPG2, but that's a high standard to meet for anything, much less an LED with a die area of, what, 12-15 times larger?
Thanks for doing that, it looks like it didn’t mist up at all on the inside. I’m not sure how it’d fare in around 5 degrees C with airflow (often its the airflow that really makes them mist due to creating such a heat differential between reflector and lense) but your test is very promising on that front anyway. I’ll have to add this to my ‘want to buy’ list It’s still $140 though so I might have to off-load some others before justifying it to myself, and then I’d be almost able to go for a Fire-foxes FF4 (6000 lumens 500kcd!).
It looks really nice design though, the UI is fine, emitter and beam is awesome. I can’t really think of anything wrong with it tbh…
“Pencil beam throwers” have their place and I do enjoy them… but there is also something special to me about a light that just puts a crap load of light everywhere.
My go to “walking light” is the varapwer turbo 3. Luminous SBT-90 led mounted on copper. Its really meant as a thrower, but since it has a big chip led and can be pushed to 14-15 amps it ends up putting a huge hot spot down field and a modest amount of spill with it.
Looking forward to the s2200 now as its a nice neutral which should work well for outdoor night time exploring
Both great lights, TK75 throws further and is similarly floody but has artifacts due to multi emietters. Tint isn’t as nice as the S2200 either. Though if I could only pick one it’d be the Fenix.
I noticed that the box for the S1100 has little notification boxes stating CreeLED waterproof standards etc, and on the S1100 it states 700m throw, in this space on the S2200 box it states 2200 lumens instead. No mention anywhere from Solarforce what it should throw. So they don’t intend it to be a thrower, just an impresser!
Not wanting to drop this beast, I learned how to tie paracord to make a tether. I meant for it to loop around my wrist and attach, but as it was my first paracord knot…that didn’t work. So I learned a new knot and made an attachment point ahead of the mode selector switch to make a handle out of the main knot, called Mated Snake Knot (the attachment is a basketweave)
But this was too big and bulky, so I cut it off and made a simpler tether, utilizing the basket weave at the tail and then a round ball to close off the loop. So now it slips over my wrist and doesn’t get in the way of on/off moves with my thumb or mode selections either, but it is secured to my wrist if I drop it or need to let go while remaining easily removable.
I like how the basket weave compliments the knurling on the battery tube.
Wire up the S2200 to a shoulder harness, turn it on hi over your head, turn in your thesis glowing like a gifted child.
Edit: Mark this post, 238, come back and check it…comfychair said it first and I’ll back him 100%, this light has the most awesome tint and produces so much useable light you will love it! Refer to this one, 238, let us know it ain’t so!
Edit II: Tail stand it in a room, any size room, and stand amazed at the gorgeous light filling the room. Overpowering the overheads most likely and almost certainly with better color. Do it. Watch.
No, others said it long before I got here (Match, in his bench tests, here, for example).
Maybe this is just the way high(-ish) CRI parts/tight binned/whatever are, but all the other 'neutral' or warm tints I've seen, I can't help but constantly think they are trying too hard to be a certain color. Shine them at something, and you're constantly aware that there is a colored light being shone onto the scene. But this one, whatever 'color' it is, it's transparent. You're never aware of what the light's color is, unless you compare it to other LEDs in the same setting. (I recommend not doing that, comparing this one's color to your other lights, unless you want to think less of the others)
Me too, can’t wait to see some beamshots and personal commentaries. Those are sweet lights and w the BTU at a new price point (and presumably the L2 U2 version not too far behind), they both have their strengths and weaknesses…not to forget the Fenix either.
With neither the SF or the Fenix being readily moddable, that already puts the ribbons around the BTU for many at BLF.
The head is nice, the switch area is nice with it’s threaded mount….wonder if a plug could be made to cap it off at the switch and wire it in to the 12V car electrical system, mount 2 of the head/switch units on a bull bar for “driving lights” WOW!
Not sure that is entirely accurate… comfychair modded his S1100, which is essentially the S2200s sister. But I understand the BTU is probably more “modification friendly” in general.
Crappy lights have more room for improvement, and are generally cheaper (at least initially). S1100/2200 needs what, exactly? Already has a very very nice double AR lens. Driver's current sense resistors are easily accessible, emitters are easily swapped. Upgrade the wiring from contact plate to driver and from driver to LED, and what else needs fixin'?
I just pulled 2 of the 3 screws off the driver cover easily. The 3rd was tight and I wasn’t quite willing to go there. But no red locktite on the first 2.
Comfy? Do you think it’d be doable to get that dielectric layer out from under the emitter if the cover plate isn’t done with locktite? I don’t like that. Want it gone.
With the 2 other screws out, gently pry the cover plate in both directions, if that last screw isn't loctited that will loosen it up (it's only located by the screws, there's no counterbore fitment of any of those parts, so it will move around with just one screw in). If you can get the plate to rotate and it doesn't loosen the screw afterwards, it's likely got the loctite curse on it.
You can lift the MCPCB up away from the base (too much heat transfer with it still touching, makes soldering difficult) and unsolder the wires without removing the cover plate.
edit: I don't know what kind of board they use with the MTG2 version, curious to see if it's the same style as the XML.
If I decided to attack this, is there a way to make the driver step up to higher amperage? Would like to see it realizing a little closer to it’s full potential…not looking for 9A but…ok 9A would be fantastic! LOL (Serial #9, order number compressed to 9 according to numerology, so why not 9 amp?)
But seriously 5A would be great. Think that would be something I could do while I was in there? Or is that getting considerably more complicated?
