It drops down from 3.8 amps and around 3000 lumens to at 2.5 amps, which is a drop of just over a third in current. Current to lumen ratio is diminishing at 3.8 amps though so it should stay over 2/3 of max output. I would be confident that high is over 2000.
You can just re-set it back to turbo in half a second with a half-press of the tailcap though so I wouldn’t worry about it. It’s really there to stop it being left in turbo unattended.
DRY driver is direct drive in turbo and uses PWM in other modes. DD makes the emitters to heat a bit more (and is not significantly brighter, at least without SinkPads). But there shouldn't be any reliability issues..
BTU driver is current regulated in all modes.
I'd suggest BTU driver if you are not planning to mod your Shocker to the full (or over).
I emailed Ric asking for a free DRY driver with the purchase of a regular BTU in NW. 5 minutes later he agreed. Ric doesnt sleep! I also ordered the better springs.
FF is already down to 14 left in stock. Better hurry if you want one! Thanks to you all for talking me into this great “budget” light. I really wanted a TK70 but couldnt commit since they cant be modified. Another loss for Fenix… oh well!
Now I have 3 more slots for the ton of sinkpads and XML2’s Ive accumulated.
I think guys have told me this light will throw right with the TK70 if not just a little better. It steps down from Turbo which is supposed to be around 3500 lumens in about 2 to 3 min to high at around 2000lumens. Red said all you have to do is turn it off and back on to turbo. And it starts the cycle all over again. That’s simple enough for me.
Just do what I did and get you one. For $99 shipped, and it runs on 18650’s, how can you go wrong?
It’s incredibly freaking bright and stays bright, the difference between high and turbo isn’t so much that you would really notice a ton except for when really throwing out a long ways. The low is actually a nice usable walking low and the medium is bright bright. I don’t know about lux but as I said it’s incredibly bright. I will probably buy one again someday.
I would say the one big concern is the size, it really is a tank. I see all the various lights with a handle that don’t really need it but this one could use it for sure. I used the lanyard a lot. I wrapped it around the head three times and it created a kind of handle, but it was a pain taking it on and off each time you wanted to change batteries.
Yea but it really ain’t as heavy as the TK70 with 4 D cell batteries in it. I weighed my TK70 I used to have on my digital fish scales that are extremely accurate. It weighed 3 lbs even. The BTU weighs 1200 grams = 2.64554715 pounds. SO even with 3 18650 batteries you should be under 3lbs.
My BTU weight exactly 1200g loaded. FYI.
Edit:
For comparison, my SRK weighs 492g loaded.
Also, the UF-T90, 1040g loaded (3x26650).
The BTU is my heaviest light so far.
My stock BTU tested at 2880 at 30sec on turbo, 2160 on high, 928 medium, 68 low.
Now with xml2’s on copper - 3670 at sec on turbo, 2520 high, 1025 medium, 75 low.
So even high is very respectable. I never tested throw on different levels, but I’d be willing to bet its still 100k or more on high.
And both tests done with 3400mah protected Keeppowers. And this is the BTU driver.
I think these are ones I used on one Shocker - really stiffens them up if your not into the soft stock ones. IOS has pretty much the same ones, believe sold as the "A" size. I got them both - went nuts buying any/all springs... If you copper braid the springs though, not sure you really need them.
Joe - think I read recently the BTU stock driver is not using PWM's at all, but regulated in all modes. The DRY driver does use PWM, and I think poorly -- read this in a BTU thread, not sure where now...
