Actually, if you check out the package deal with charger and batteries, there’s 96 more.
Ric might start selling those lights by itself when he starts to see it move.
Who knows, 96 is still quite a bit. Another price drop is possible.
Don’t you guys hate missing a great deal about as bad as I do? I guess seeing others take the plunge makes it that much more psychologically correct to do so and ever so much more rewarding justifying the submit payment button.
I’m still hesitating on getting one, even though I have no real throwers bar my N30 HID (which does around 250 kcd). I would probably go with neutral white, even though there seems to be around a 15-20% output drop (the readings in the NW review are a bit underestimated).
That's one reason why I love my NW Shocker: It's bright enough! I don't need to think if I lose some lumens or candelas because of NW. Of course there's small difference, but you won't really notice it without comparing to another Shocker.
I think it should be marketed like Rolls-Royce: - Lumens: Enough - Throw: Enough
Or what does Mr. Admin think? Is the NW enough, or would you like to have some more lumens?
I would go BTU for good regulation and no PWM. I doubt the DRY driver nets enough additional output to be worth the negatives (low frequency PWM, unregulated) or even enough to be noticeable.
DrJones says 260Hz on low for the DRY driver, but I’ve read some posts alluding to 700Hz, which is still slow if you’re PWM-sensitive or just don’t like having visible PWM.*
I think you’ll be happy with the BTU driver
*For context, the SR King’s Low mode is 178Hz PWM and impossible to not notice, and the ever-popular 8xAMC Nanjg105c variants have (something like) 4000Hz PWM for modes which is for the most part unnoticeable. Hope that helps!
My last objection is that if I don’t get the DRY driver with turbo, this won’t be as much of a use, given its weight and identical output to my King. It would just have the throw. I don’t know if I can justify that.
