BTU Shocker - $99 Free Ship at FF
BTU shocker NW review: Review: BTU Shocker (3 x XM-L T6 NW | 3 x 18650)
BTU shocker CW review: Review: BTU Shocker (3* XM-L U2 CW, 3* 18650) - comprehensive (picture heavy).
I’m still hesitating on getting one, even though I have no real throwers bar my N30 HID (which does around 250 kcd). I would probably go with neutral white, even though there seems to be around a 15-20% output drop (the readings in the NW review are a bit underestimated).
That's one reason why I love my NW Shocker: It's bright enough! I don't need to think if I lose some lumens or candelas because of NW. Of course there's small difference, but you won't really notice it without comparing to another Shocker.
I think it should be marketed like Rolls-Royce:
- Lumens: Enough
- Throw: Enough
Or what does Mr. Admin think? Is the NW enough, or would you like to have some more lumens?
Oh the heat I’m feeling!!! Guys, this is awful! Really!
So should I do the DRY driver or BTU and why?
I would go BTU for good regulation and no PWM. I doubt the DRY driver nets enough additional output to be worth the negatives (low frequency PWM, unregulated) or even enough to be noticeable.
Just get your hurting over with and buy the damn thing. LOL!
Cool white BTU Driver is what I got. That seems to be the best going on the comments here.
So that PWM is really noticeable?
sweating
DrJones says 260Hz on low for the DRY driver, but I’ve read some posts alluding to 700Hz, which is still slow if you’re PWM-sensitive or just don’t like having visible PWM.*
I think you’ll be happy with the BTU driver :wink:
*For context, the SR King’s Low mode is 178Hz PWM and impossible to not notice, and the ever-popular 8xAMC Nanjg105c variants have (something like) 4000Hz PWM for modes which is for the most part unnoticeable. Hope that helps!
My last objection is that if I don’t get the DRY driver with turbo, this won’t be as much of a use, given its weight and identical output to my King. It would just have the throw. I don’t know if I can justify that.
This is painful!
I know, I’m on the fence too. Problem is that it’s not a fence I knew I’d be straddling right now. It’s wicked tempting.
On the bright side one can easily mod the thing or have somebody mod it to kick the King’s butt in raw output.
Edit- Thankfully I don’t have to worry about buying it because my ISP has decided it can’t find the FancyFlashlights site (or CNQualitygoods for that matter). Fortitude by proxy is better than nothing.
I think its a stretch to consider output “identical” to the King. The NW review said it’s about the same as… That is not identical.
Shocker has tons more throw. With tons of overall output. It puts the TK75 to shame out the box, and can be modded even better. I understand the comparisons to the King since they are both triple XML, driven pretty hard. But you really can’t group them together as that similar. It’s the combination of both mega output and throw that is so unique and awesome with the Shocker. It’s pretty easy to have tons of throw OR output. Lots of [cheaper] options for one or the other.
OK, so a BTU driver-equipped Shocker would have more output than a CW King? If so, by how much? I’d love to justify this enough to pull the trigger.
The CW BTU in stock form is already about 600 lumens over the original SRK (2200otf) and at least double the throw. Buy it Joe. At this price I promise you wont regret it. Later you can get it modded and very few led lights will touch it in combination of flood and throw.
that was my point
I am just going off what I have read, I don’t have a shocker. I do have a King clone FWIW.
I saw your post saying basically the same thing after I posted. Evidently I type too slow. Three posts showed up in the time I was typing my reply. Lol.
Joe - As manxbuggy1 and Haterade said... But also the new stock Shocker comes with an AR lens which it didn't have originally, so the new BTU driver/CW ones I've been testing stock are doing over 3,000 lumens - 800 over the king, and the throw, for get a bout it.
Fine. I can resist no longer.
Batteries. Dont forget batteries.
@ Rusty Joe……
Buy the friggin’ thing!!!
It will put pretty much any light to shame, including the ‘king’.
…the ‘king’ is dead, long live the king.
Maybe the MT-G2 version is coming……. :smiley:
I want one off those but if it was it wont be $99.00. :_(
