My fav is my $9 Ultrafire C8 - small enough to go in my pocket at work but bright enough to inspect the undercarriage of cars even in opposing backlight.
actual otf lumens is closer to 350-375, but still, its decently driven and has enough cooling to actually use it as a handy pocket light without cooking your hand.
It’s a compact twisty with shitty but working clip, nice design (in my opinion) and relatively good output (outshines all other low price lights from this budget class). Around 10-15lm output, nice “throw” but with rings (since very symmetrical they don’t bother me). NW tint.
roughly 4+ hours with a fenix protected 2600mah 18650, though it gets too hot to hold after about 15 minutes indoors. had it in front of a fan to test runtime, as I always do with a new light. should be considerably longer with panasonic 3400’s. I usually test with the fenix cell first as its protected, and proven itself to be a ‘true’ 2600 mah cell.
I just got this light the other day. Not bad for an $8 light. Reflector is deep and smooth. It’s got a definitive hotspot with lots of spill around it. Reverse clicky switch. Only thing bad is that it’s next mode memory.
Thanks for pointing this out. I blocked the accounts of all of those shills that had the same IP address range (they were using an anonymous proxy). There was no IP address record for the others, but if they come back they will be deleted again.
