Comfy,
Do you know the voltage drop across the resistors? Since they appear to be in parallel it would the same across all four (so no need to measure all four other than to confirm their parallel topology). Knowing that voltage drop (current output to the emitter is helpful too) will let us determine what values to add to set emitter current at 5A.
No not ready to dive into that right now, got too many other things in a million pieces already... S)
Anyone that ordered after solarforceflashlight-sales went on hiatus, got a shipping confirmation/tracking number yet?
i ordered last week… and no… im still waiting
Y’all will be pleased after the wait, I’m loving this light! Even use the lo mode regularly, just love the color of the output and it’s very nice all the way around. Well worth waiting for.
I have not received a shipping notification either. A little annoyed to be honest…
I'm going to be downright frustrated if it arrives during my exams.
Blind the professors with your new light and steal the test answers.
From Solarfoceflashlight-sales.com:
Well I’m glad they took an unscheduled 5 extra days of vacation and still havent shipped my light…
Just got my shipping notification and tracking number. Yay!
RB972370495HK
when did you order ramblings? just so we can get an idea of how well they are getting through the back log of orders
I just got notifications for the orders I placed on 5/18/13 (S2200) and 5/20/13 (L2M & SS Pocket Clip)
ok thanks… i ordered on 5/26 so i should get notification soon i would think
I ordered on the 18th of May.
i got my shipping notice this morning woohoo!
Ok, trying something out…let me bounce this off you guys. I reckon most here know by now I’m a photographer. I use Canon equipment. The lenses (L series) come with hoods and I use them to keep light refraction from making green spots in my pics. (When a direct light source like the sun hits inside the lens this refraction bounces around off the AR coatings and causes red or green splotches, opposite the angle of the light entering the lens tube)
So, if a hood can be used to shield light coming IN, why can’t it be used to direct light going OUT? The S2200 puts out a very wide beam with tons of spill, but as a result it’s throw is reduced somewhat. So I made a hood for it. Tightens up the projected light considerably, but don’t know yet if it helps throw…only beam shots will tell. My hood adds about 4 1/2” to the end of the light. I’ll try to get some beamshots tonight with and without and we’ll see how that works!
Would love to hear some opinions before the tests, so hit me with your best shot! lol
Quick and dirty, not finished, no finesse shot of the light with hood…
I think you will perceive increased throw, but only because the shield will reduce the amount of light on stuff between you and the target, making the target seem like there's more light hitting it. A light meter at the target would very likely read exactly the same with & without.
Bringing the side spill into the game doesn’t push it any further downrange as it doesn’t change the core power. But it won’t be a matter of perception once I get pics of the resulting beam. (Any excuse to set up and take pics is a good enough excuse for me! )
On the other hand, in researching what makes the best reflector, the science says depth creates throw. A shallow reflector isn’t capable of gathering the light that leaves the emitter at an angle that escapes the desired trajectory before the walls of the reflector can gather it and redirect. So it might prove interesting to see if this hood has that kind of effect, even marginally. This science proves solid when looking at the result of a small emitter vs a large one, the radiant angles of light dispersion are more aligned with a forward trajectory in the smaller die thus elimating the extensive need to redirect the beam into a forward core. The larger die has more angle of dispersion, creating need for deeper walls in a reflector to gather and channel it.
This isn’t my argument, mind you, but the science of the companies that make the reflectors in the first place. Of course, I could have it all wrong…
I frequently get it all wrong. It doesn't seem to cause any permanent damage. :p
I wonder what would happen if you lined the inside of your “hood” with the shiny side of aluminum foil, making it as smooth as possible?
BTW, how’d you attach that to the bezel?
