And yes there is no proper driver for using Nichia 219 in general or XM-L2.
No good single or multiple cell drivers able to do boost/buck at 1.5A or 3.0A. (Efficient and programmable with a flat stabilized output curve.)
If the batteries suck enough then yes. But you will overload them, the batteries may not be able to give you the necessary current so they drop voltage a lot. If it’s some tiny and low capacity batteries, cheap brand batteries, that is quite common.
Sure you can’t do that with 2x good 26650 as they won’t drop and will burn it.
Also overloading the batteries means loosing usable capacity. You get more runtime when they are not overloaded.
Now that you are surprised I am not so sure anymore.... The voltage of 2 16340's under the max 4.4 A load that I tested will not be 8.4V but much lower, but perhaps not as low as 4.8V (the voltage at 4.4A), hmm, better be careful then .
Thank you for the response. I guess you’re saying there is no point because the lumens per watt peaks around 3A in your test. Is that correct guess? I see your graph, but your table shows lumens continuing to climb, but at a progressively slower rate, up to 4.5A. I don’t want to slow down your thread educating me. So no response is necessary. I need to go learn more about lumens and OTF. I just thought OTF was lumens net of light lost in the reflector and lens.
Yes, the lumens peak around 3A (the lumens/watt probably peak around 100mA ) In the table that is also the case, but you may have read the voltage colomn as current?, the current is the first colomn. And I am only glad when people learn something from what i write down , just a few months ago a lot of the number stuff was new to me, I was glad to learn from others as well
ha! You’re right. I was reading volts as amps. Thank you. Makes sense.
I don’t know why I didn’t realize that. The testing done at CPF showed the 219’s efficiency drops pretty fast as current rises. They only tested up to 2A if I recall.
I’m excited to drive one at 3A. I’ll report back on how it goes. Thank you for work you did here again.
Unfortunately this is exactly what is the pain with the high Vf of the 219. Lineair drivers like the 7135 regulator Nanjg driver adapt the output voltage to the Vf of the led so that they provide constant current, also with the Nichia 219 (as long as the battery can provide the voltage needed -another problem with the high Vf-). But drivers like the Z8 driver, and also cheap boost drivers as found in AA-lights or cr123 lights put out a current that is (also) dependant on the Vf of the led. So the 219 with its high Vf (that is: Vf is high at the higher currents) will always disappoint. I used a BLF-mini driver in a 219 build, in the Trustfire Mini01 it puts out a satisfying 2+ amps to the XM-L, with the 219 I only get 1.3A (which is actually a nice current for the 219 on a alu board).
With the 219, if you want more light, add more 219’s. Adding current makes more heat than light. 1-1.5Amp is a sweet spot. Lumen/watt really drops fast with these.
The B10 219 Illumination Supply has are the ‘low Vf’ lot. 1Amp drive is about 3.5 volts. (edit; mine are closer to 3.3V at 1Amp)
Yeah, take my comments with a grain; If you are after absolute max regardless of current/heat/efficiency, there is still room to push, (maybe 2-3 amp?) But the Hi CRI 219 benefit vs. XP-G2 or XM-L de-domed; these are much more suitable for pushing hard. At least you are rewarded with lots of Lumen for your efforts…
In the OP it is also said that my data are not quite calibrated and that I suspect that the actual Vf is about 0.15V lower than what the power supply measures, so at 270mA that would be 3.05V (and that comes close enough for me to the 3.025V that is undoubtedly more accurately measured than I did )
perhaps the ld29 driver from intl-outdoor, or this one, also from them. I think the ld29 is nice, because 2.8A is just a bit more optimal than 3.0A. The driver is 20.3mm though, not suitable for every host.
