hi flitsmal, to directly answer your question
I honestly don’t know :bigsmile: that’s kind of the point of trying it out.
I have the two xp-g c8 reflectors from cnqg, brass pills with emitter pcb hold down screws from fasttech, I now need noctigon 20mm xp-g2 stars from intloutdoor and qlite drivers and some more 7135’s, then I need a source of c8 hosts that fit the pills, cnqg has an ultrafire c8 host, I have high hopes of that doing the trick, I’ll also want some ar coated lenses, then I can try various combinations to see what works best, as I’ve done a couple of xp-g2 builds that “look” like they throw well, I now need a light meter to quantify these results.
What will the light be like? it’ll be a c8, just hopefully a c8 with decent throw and some spill, the xp-g2 has a noticably narrower beam angle compared to an xm-l, in my other builds, you get some spill, just noticably narrower than an xm-l with everything else the same, its not as bright as the latest xm-l2’s but certainly comparable to a modestly driven xm-l t6 you’d get out of an ebay light, the two builds I’ve done have been a 1c in a uf-v3 at 2a, its a very very crisp white light that I find nice to use, the second is a convoy l2 (huge reflector) with an xp-g2 3d driven at 3a, that is at least as bright as the last couple of ebay xm-l lights I received, but with a really nice nw tint.
What I intend to do is build two pills, both about 3.8a (two extra chips added to the qlite drivers) one with a nw xp-g2 on noctigon, one a dedomed 1c ish emitter (dedoming tends to warm up the tint a little) I’ll then be able to compare the reflectors I have to see which give a nice beam and (assuming I get a light meter at the same time) which gives the best recordable throw, then, I can actually make informed suggestions as to what someone else might like.
To give you an idea of output, tom e mentioned he’d built up an xp-g2 xintd c8, dedomed at 3.8a, he’s getting 125kcd, that’s where I’m hoping to get, and the reason I want a light meter, I wish to quantify what I’ve already built, then I have a base line to see how things improve and see how builds work out compared to other lunatics like myself :bigsmile:
