Interesting. I thought MariaDB would go down first. Or maybe the entire OS.
Know of an easy way to configure this perchance?
iptables -A INPUT -p tcp --syn --dport 80 -m connlimit --connlimit-above 10 -j REJECT --reject-with tcp-reset
You can send the wget downloads to /dev/null instead of filling up your drive, no?
sb56637: Aleister:I think you might want to consider setting a maximum concurrent connections per IP limit… I know this is a test but any server would be slow if a bunch of people were downloading everything at the same time.
iptables -A INPUT -p tcp —syn —dport 80 -m connlimit —connlimit-above 10 -j REJECT —reject-with tcp-reset
Thanks!
Last time I needed it I asked my host to do it for me but let me check on my server for a minute. You have WHM + CPanel, right?
Edit: Aaaand it’s answered already by another member! I love BLF
True, so you could add "-P /dev/null"
I don't know, I'm not too savvy on all the terminal commands. Pretty new to linux
wget --recursive --page-requisites --html-extension --convert-links -domains 198.199.90.139 --no-parent -P /dev/null/ http://198.199.90.139
Fantastic support isn’t it. To answer your question, no, I don’t have any control panel. Just a barebones CentOS 6 shell. For that reason, I might have a few questions in the near future for PilotPTK about my httpd.conf.
PM Away SB - I'm happy to help.
SB You should really consider building/buying a NICE server (8Gb+ RAM, SSD, Intel Xeon or i5) and then just having it hosted. There's a place less than 5 miles from my house that has Burstable Gigabit connections, 100MB guaranteed, 2TB/Month of Transfer, Battery and Generator Backup, Security, the works.. For a Mid-Tower or 1U Rack Server.. $50 per month.
Then you control the hardware.. Need more RAM? Ship two sticks of DDR3 to them and they'll install it in your box for you. Small tasks like that they usually do free of charge.
I'm done for the night. Just stopped all threads.. Let me know if I can help.
Last Thread:
Transactions: 4000
Elapsed time: 1989.436 sec
Bytes Transferred: 152,245,863 bytes (152 Mega Bytes)
Response Time: 39.49 sec
Transaction Rate: 2.01 trans/sec
Throughput: 76527.14 bytes/sec
Concurrency: 79.4
Status Code 200: 3848
Status Code 502: 35
Status Code 503: 108
Status Code 504: 9
I’m done for the night. Just stopped all threads… Let me know if I can help.
Thank you VERY much! PM sent.
it seems like its been crashing alot lately
Its slower for me.
And it stopped loading. I got this instead:
“Oops! Google Chrome could not connect to 198.199.90.139”
Not sure if anyone else is still “testing” it. I still am using my PC overloading the server.
I’m having trouble with it now too. I’ve rebooted it a few times now. I suspect that it needs to have the maintenance tasks run after that heavy load, and I can’t run them because of a configuration problem on this testbed.
Yeah, I think everyone but you has signed off by now, I already stopped testing.
