Yup, I’ve been saying these lights are awesome from the beginning. Now everybody is seeing the light
As a side note about the TN31 and BTU, from our experience they are very comparable in throw. We’ve had two BTU and two TN31’s now. This is what we’ve gotten in throw -
TN31 (brothers)–126K
BTU (mine-no AR lens)–125K
BTU (mine with UCL)–130K
TN31 (mine)–121K
BTU (brothers-no AR)–119K
So pretty equal really. I guess just slight variances in qualities in LED bins or drivers can make one slightly better than the other.
Well my TN31 I used in that shot above was tested by masha_1 to be 115,000 lux. I would say it’s safe to say that the BTU I got is more like 130,000 or maybe more. I do believe there is more than 15,000 lux between them just looking at the pictures at 110yds. The BTU smokes the TN31.
rdrfronty, are those BTU numbers from yours that was modded by Tom E? Mine is on the way to him to have XML2’s on sinkpads installed as well as a resistor upgrade to bring it up to 4.7A. I can’t wait >_<
Regardless (don’t use glasses for computer usage), this thread, along with the $99 price, got me interested in this light again, so I ordered one with the BTU driver, plus an extra DRY driver, just in case…
Nope. Like the others said that was premod. Mine is now 181K and 3670otf after 30sec. Thats with XM-L2 U2’s, copper sinkpads, better wires, and good thermal paste. I do not have the resistor mod though. I am getting my carrier redone with better springs and/wick mod, so that should allow a little more current and boost me a bit more. My testing was done with Keeppower 3400mah protected cells.
The heat from 5A would probably reduce efficiency by a lot and just waste power now that I look at the xml brightness curve, mainly because there’s three in one host.
The Shocker can take a huge amt of current with copper stars - it's a beast! I ordered 18 gauge wire from Hank at IOS, wondering if I should wait on it to use, rather than the 20 gauge I got. The resistor mod will get it up there in amps, 4.5 to 5.0. There are 3 emitters putting out heat, but you may have at least triple the heat sinking of a HD2010 for example.
Brad - your 115 kcd to me looks about right, compared to the Shocker. Your new one with the real AR lens does very well, about 130 kcd, so the difference you see match's the difference in kcd I'm think'n. TN31's of course are a nice light to mod - mine does 347 kcd - de-domed XM-L2, resistor mod. Last night played with the TN31 and man, it still puts out a nice wide beam compared to other throwers I got, and still puts out good amt of light. De-domed XP-G2's can do better in throw, but reduces the beam width and total output quite a bit.
Modified BTU Shocker has 3600 lumens and 180kcd of throw, it is in HID territory really, at least it can eat up some 35W ebay HID. 4300K 85W HID has better colour temperature, higher lumens output, longer throw, and even lighter weight than BTU Shocker (with battery), but it is too long to carry around.
I always suspect if my 6500K 85W HID performs properly, its output looks not so bright. I wish to change into the 4300K module.
