Ok. I’m at work and it just came to me. It’s going to be an angle light with a twist. I’ll post some pics when I get home from work
now let me try to make this post an actual build thread:
this is what i got so far.
its going to be an angle light made from copper pipe and brass fittings.
the on/off switch will be on the back side of the elbow for activation with your thumb
its got a 3” reflector from a cheap rayovac lantern
think im going to put an xml, direct driven in it
either going to run it off a 3xAAA carrier, or sleeve the tube for an 18650
dont have much done yet, but here is the concept
ruffles was kind enough to search for some copper rod for me while at his metal dealers yesterday, so i should be starting on a heat sink soon
thank you ruffles!
things to come:
working on smoothing out the cast bronze parts and polishing. not easy with out a dremel
heat sink should be started this weeken
