Review: USB battery box 4x18650 Coolook PB-2000
92 posts / 0 new
lehachuev
Last seen: 8 years 7 months ago
HKJ wrote:
If there is any interest I can make a illustration on the pcb photo.
Please make it!
HKJ
HKJ's picture
Last seen: 1 hour 41 min ago
lehachuev wrote:
Please make it!
Recoding A output to USB standard, i.e. not Apple:
Remove the four resistors wit a red cross and short the two points with the yellow line between.
Ouchyfoot
Ouchyfoot's picture
Last seen: 10 months 2 weeks ago
Can I charge this from a wall outlet using an Apple ipad adapter?
HKJ
HKJ's picture
I do not know anything about the ipad adapter and cannot tell you, maybe somebody else can?
lehachuev
Thank you!
Ouchyfoot
Ouchyfoot's picture
I’ve been looking at this USB batter box , but can’t find any reviews.
Racer
Racer's picture
Last seen: 5 years 6 months ago
Thank you for the excellent review!
Maybe you can answer a general charger/power pack question I have: My ZTE Engage smartphone is very picky about what will charge it. The two battery packs I have built already will charge the wife’s HTC One but not mine, my guess is because of something to do with the data pins. My power packs only use the + and – wires. So my question is about what certain chargers do to make the device it’s connected to think it’s connected to a computer, and how to know which chargers do that. Thanks!
HKJ
HKJ's picture
Racer wrote:
So my question is about what certain chargers do to make the device it's connected to think it's connected to a computer, and how to know which chargers do that. Thanks!
Try checking the link in the "Notes" section of the review, at the bottom of that page is a table that might be useful.
Chloe
Chloe's picture
Last seen: 5 years 5 months ago
This looks like a nice box, with different voltage outputs and display.
FoxUnit
FoxUnit's picture
Hi HKJ, got some question about the USB power adapter that come with this box(purchased from fasttech)
What kind of coding does this one use?
I figured that they are 6.2 kΩ on both D+ and D- pulldown, 5.6 kΩ on D+ pullup and 10 kΩ on D- pullup.
Edit : Just cut some crappy USB cable and check it with DMM and yes, it’s Apple 2.1A coding. Smile
HKJ
HKJ's picture
FoxUnit wrote:
Hi HKJ, got some question about the USB power adapter that come with this box(purchased from fasttech) What kind of coding does this one use? !http://i1053.photobucket.com/albums/s469/DontMi/coding2_zps84543592.jpg! I figured that they are 6.2 kΩ on both D+ and D- pulldown, 5.6 kΩ on D+ pullup and 10 kΩ on D- pullup.
The best match is Apple 1A, but the voltages are slightly high for that. I do not know if a Apple product will accept it.
FoxUnit
FoxUnit's picture
HKJ wrote:
FoxUnit wrote:
Hi HKJ, got some question about the USB power adapter that come with this box(purchased from fasttech) What kind of coding does this one use? I figured that they are 6.2 kΩ on both D+ and D- pulldown, 5.6 kΩ on D+ pullup and 10 kΩ on D- pullup.
Sorry for late update, just cut some cable and check with DMM and the voltage match the Apple 1A coding (got 2.001V on D+ and 2.702 on D-)
Edit : I was wrong, it’s 1A as HKJ said
transposon
Last seen: 4 years 9 months ago
Thank you for these great reviews HKJ. It really helps to get an idea of what these products are so we don’t have to order blindly.
I have a question about using cells of different voltages in this or other boxes. Why is this not a good idea? Shouldn’t they balance each other out since they are in parallel?
Also, would using different types/rands of batteries within the same box be OK? (eg Sanyo UR18650FM and Panasonic NCR18650B)
And lastly, Any chance that you could review this USB battery box?
QIDIAN 3-Piece 3A 1-4*18650 Dual USB Output Mobile Power Pack Battery Charger Kit
https://www.fasttech.com/products/1420/10004461/1341401
Thanks a lot.
HKJ
HKJ's picture
transposon wrote:
I have a question about using cells of different voltages in this or other boxes. Why is this not a good idea? Shouldn't they balance each other out since they are in parallel?
They will balance each other out, usual in a couple of minutes. To avoid this high cross current, it is better to start with about the same voltage on the batteries.
It is the same when charging in parallel, it is recommended that the batteries are close in voltage, before you start.
It will work, but you might not get the full advantage more batteries. With four of the same, they will always share the load. If you mix UR18650FM and NCR18650B, the UR18650FM will have the main load at the start and the NCR18650B will have the high load at the end.
transposon wrote:
And lastly, Any chance that you could review this USB battery box? QIDIAN 3-Piece 3A 1-4*18650 Dual USB Output Mobile Power Pack Battery Charger Kit https://www.fasttech.com/products/1420/10004461/1341401 Thanks a lot.
Yes, there is a very good possibility. I have it in queue (That means that I have), but that queue is rather long at the moment, i.e. it will probably be more than a month, before I post a review.
picrthis
picrthis's picture
Last seen: 10 months 3 weeks ago
I bought just bought this one myself JIB LB20000
Fenix TK12, TK15, TK21-U2, TK61, TK75 Olight M20S, M21<span style="color: #0000ff;"
Bergtjie
Just to let everyone know , mine came from fasttech and it happily charges my iPad and iPhone -:)
I’ve actually ordered another for our camping trips.
RaVeN
Thanks for the great review!
Going to buy this from fasttech as they’re providing a suitable ac adaptor.. Problem is that I’m in Australia so I need a converter from here: http://www.fasttech.com/products/1183109
Should I get the 6A or the 10A one?
HKJ
HKJ's picture
RaVeN wrote:
Thanks for the great review! Going to buy this from fasttech as they're providing a suitable ac adaptor.. Problem is that I'm in Australia so I need a converter from here: http://www.fasttech.com/products/1183109 Should I get the 6A or the 10A one?
6A is more than enough, but you might want the 10A to get a more solid adapter.
RaVeN
Sorry, what do you mean by more solid adapter? Is there a better one available somewhere I should be buying instead? Or did you mean that with the 10A it will work better?
Also, will panasonic 18650 protected batteries fit? The length is 69.4. I know you said 70 is the maximum length, just double checking Silly
Thanks alot!
HKJ
HKJ's picture
I would expect the 10A adapter to have a slightly better construction, because it must be able to sustain higher current.
I do not know of better adapters, but there probably is.
RaVeN wrote:
Also, will panasonic 18650 protected batteries fit? The length is 69.4. I know you said 70 is the maximum length, just double checking Silly Thanks alot!
Yes it will, but probably a tight fit (Sorry, I am not near the box at the moment).
RaVeN
Alright, purchased. Thanks for the help Smile
Empire
Last seen: 8 years 1 month ago
A shame it doesn’t have digital readout, like some of the boxes out there.
Empire
[/quote]
Check that plug charger is dangerous.
http://www.lygte-info.dk/info/usbPowerSupplyTest%20UK.html
FoxUnit
FoxUnit's picture
http://www.lygte-info.dk/info/usbPowerSupplyTest%20UK.html[/quote]
Which one do you refer to in HKJ site?
iron potato
Last seen: 1 year 4 weeks ago
I strongly recommend to get this USB power adpater
My niece bought one lookalike as JIB LB20000, she told me she just able to fully charge her iPhone 4 about 3-4times.
I pry open which also in turn, broken all the plastic hinges, the PCB charging current is +-800mA measured.
Inside consists of eight 1100mA noname blue wrapper 18650 batteries, which takes 11 hrs to fully charge the unit.
While I do not own the JIB version, maybe it uses different battery.
She’s very happy that I gave her one of my portable power supply, consists of two Sanyo Red 2600mA and a 4 ports USB wall adapter, in terms of compactness, hours to charge the portable power supply & able to charge her iPhone 4 about 2.3times.
picrthis
picrthis's picture
Thanks for pointing that out to me, but it looks like it is the 240 volt version, whereas I got the USA version with the 2 flat blades and I don’t see that model in the review, with that said though I haven’t even used the usb plug-in charger it came with, rather I used the Samsung charger that came with my phone. The battery power box itself seems very well built and arrived 3/4 charged already, took no time with the Samsung usb charger to top it off.
Again thanks for the heads up, to be safe I’ll probably not use the included usb charger even though it’s a different model than reviewed.
mfm
Last seen: 12 months 4 days ago
HKJ wrote:
Charging four 3100mAh batteries takes about 9 hours and requires a charger that can deliver more than 2A.
So the specifications saying “Charging input: DC 5V, 0.5A~2.5A.” is wrong? And you can’t use a normal USB charger but need a custom DC power supply?
Why? It’s surely fake and not the adapter tested in the charger tests mentioned earlier?
HKJ
HKJ's picture
mfm wrote:
So the specifications saying "Charging input: DC 5V, 0.5A~2.5A." is wrong? And you can't use a normal USB charger but need a custom DC power supply?
One detail I do not check, is how the charge circuit handles lower input voltage. If it reduces the charge current, it will probably work with most chargers.
You can get USB chargers that are powerful enough to handle this box at full charge current or you can take the batteries out and charge them in a normal LiIon charger.
mfm
Can you recommend any 2.5/3A USB chargers that are USB charger coded and not that dodgy?
HKJ
HKJ's picture
Probably not.
USB charger is only rated up to about 1.5A. This does not prevent it from delivering more current, but manufacturers may chose to label it as Apple 2A.
USB chargers with multiple outputs are usual the best, they often run all the outputs in parallel, i.e. a charger with 4 0.5A output, will have a total of 2A, that can be drawn from any port, as long as the other ports are unused..
