Yupp. The results are basically the same.
Its the “IOS 3 mode 3-18V driver” I used… Maybe you should just call it that since both you and I have tested it but calling it different names (Im thinking about the description in OP.)
I just used the product descrption from the IOS webpage.
I know Relic38 have resistor modded that driver in this thread and used it in combination with MT-G2.
I shared a build with relic38 using a DRY driver in a Trustfire X8 clone. The reason being the X8 has 19/20mm driver groove, and the clone has a 22/23mm driver groove on the first step and and 19mm groove underneath. Of course the DRY specs are:
PCB diameter: 23MM
for 3*CREE XM-L T6 LED in series.
Input voltage:7.4V~12.8V
4 modes:
Lo——0.1A
Mid—0.5A
Hi-2.25A
Turbo—Direct Drive Max 4~5A; Turbo mode will step down to Hi mode after 120 secs in order to protect driver and emitter from burning.
With mode memory
Using turbo is DD, and the actual output depends on the cells and what they can deliver, ruff estimate 7.4 volts to the emitter, and ruffly 4 to 5 amps. relic said it got 2000 otf lumens, relic can post results here: The DRY works well and is only $5…
Flomotion’s numbers match mine fairly closely. Using Sanyo UR18650ZT cells, I get right around 5A on turbo and just over 2000lm OTF. It is advisable to leave some resistance in the light, although I’m pretty sure I addressed all areas J) (springs, wires). I used a Noctigon, which is highly recommended.
Not bad for a two-cell light this small.
The beam is somewhat floody with a very large hotspot. On mine there is a slight ring around the hotspot, but only noticeable when white wall hunting. Outdoors, this is a very nice flood light, that can throw pretty god too. I didn’t measure throw yet though.
Flomotion has a build thread somewhere. I Probably should have answered this question there.
Even if the cells sagged to 4V each at turn-on, that would still be 12V * 9A at the tailcap = 108W before driver losses to the emitter. Either way, this is beginning to sound very interesting!
This build is very dependent on the cells that are used, the better the cells, the better the light runs. Now the host is a cheapie, but does have more mass and size in the pill area than the “real” Trustfire X8. I real X8 pill module is not big enough for the DRY driver, so that option is out. The DRY will take 3 cells (don’t try it, will fry the emitter), and I noticed that people were posting using 3 cells on the IOS driver, so the DRY ought to be similar on three cells in series (definitely a NO, NO). I have not done that(Good Thing). Thanks for having my back relic, on this, he is much better at posting than I, but we did get similar results on the same build. I was really amazed at the build, the idea being, the the MT-G2 is very floody by nature, so I wanted a deep reflector and fairly narrow beam to contain the floodiness, and the idea worked. There is still plenty of spill in this built, but the hotspot is well contained: but quite large. There does seem to be some interesting chromatics in this build, variations of tints of yellow and white, but rather interesting than annoying. Relic can do better on the measurements of throw, but I was impressed at the throw for just 2 cells. The torch is gobbling every electron you give it, so like relic indicates: it is a very small light pumping Boo Coo amps, but seems to handle the thermals, and the MT is demanding everything from the cells, so it does get warm quickly. With the final drive being Turbo or DD, I would guess that counting efficiency and points of resistance, this is about as much light as one could expect from a torch this size at the present without things starting to go into thermal/electric failure…just my view, relic is free to add his view…, remember this is a bottom of the barrel — budget build, for this powerful of a light…at this time…
A word of caution. Do NOT use the DRY driver to drive one MT-G2 from three cells in series. The emitter will die a quick death. Quick, as in you will not get a chance to turn it off.
The IO driver is a buck driver, so it will convert the power from a 12V/1.5A level down to 6V/3A level (halves the voltage, doubles the current) in order to keep the current in check.
The other points you make are in line with my findings so far. I’m charging my Sanyo cells right now and will test output again for documenting purposes.
For about $45, this is the lowest cost and simplest MT-G2 mod I’ve seen yet. The ZY-T08 mod was more expensive (could have used a DRY driver there). It was also more work, however if it had actually worked from a 2P configuration, it would have been easy.
OK, here are some results using fresh Sanyo ZTs charged to 4.3V
Drive current: 4.7A
Total output: 2238lm at start, 2045lm after 30 seconds (mostly battery sag, power supply shows much ‘sturdier’ output)
Throw: 19.2kcd after 30s
So it’s not bad. Would like to have a regulated boost driver to keep them lumens going steady, but you would need IMR cells for that (battery current would go over 2C as the cell drain).
You can get away with regular 2600mAh+ cells with this setup.
Pretty impressive, but like you say, it is an electron hog, and eats batteries quickly. I was quite happy with the build, do you think using the DRY in another build going 2S2P would work? Thanks again…
