Test / Review: AW IMR 14500 600mAh (Red)
Official specifications:
  • Nominal Voltage : 3.7V
  • Capacity : 600mAH
  • Lowest Discharge Voltage : 2.50V
  • Standard Charge : CC/CV ( max. charging rate 1.5A )
  • Cycle Life : > 500 cycles
  • Max. continuous discharge rate : 4A
  • Operating Discharge Temperature : -10 - 60 Degree Celsius
  • Size : 14.07mm ( diameter ) x 49.25mm ( height ) +/- .1mm
This is a high current battery.
The battery handles the different loads very well.
Conclusion
This IMR cell handles loads very well, I will rate it a good cell.
Notes and links
Thanks very much HKJ! Frontpage’d and Sticky’d.
Love your in depth reviews and recommendations. Don’t know what we’d do without you!
Thanks for another very useful review. I use your results very regularly to calculate the possibility of a flashlight mod, before building it.
