Anyway, That 20W is quite a bit larger at 7”W x 5.5”H x 4.3”D
The 10W one I have is 4.5”W x 3.5”H x 3”D
Edit: Depending on shipping, that’s not a bad price either ($27, doesn’t ship to Canada)
I have the fasttech 10W 12V led driven with 700mA on a finger heatsink like this
As a desk lamp and it gets hot maybe 60°C but that’s nothing bad it works and makes nice floodie light….
And if I consider that I have really small Tubular flashlight with 8W LEDs… I think that it should work with such big housings…
But I think you are right that heat isn’t good especially if you use this light continuously for lightning. I would use this as a working light and for playing around or so and the huge 12V emitters aren’t really efficient…
Maybe I will check the light out later, haven’t put my hands on it for about half a year.
How is your mounting piece on your lights, mine wasn’t really build up well if I remember correctly…
Edit: I have just searched my light and I think the 3T6 driver should fit in the driver compartment, that would give me a nice voltage range and even modes. And nice regulated current. Maybe I use two XMLs parallel driven with 4.5A…
So I just ordered a pair xml2 T5 3C.
If you are referring to the 10W worklights, the emitter is directly mounted on the main light housing. It could not be better. One improvement would have been anodizing the housing instead of paint. Still, at 10W, it is fine. I think it could be pushed to 15W with a bit better driver.
Yep, I guess 15W should be OK and that’s what the stock 3T6 driver does from 4-13V…I have just looked up and xml2T5 does 630 lumen @2A so I guess at4.5A it should be a nice floodlight with 1200lm or so.
Nice hint with the paint, I am going to grind it away…
I will try to solder 2 XMLs on one star like I have seen it here somewhere, maybe I can grind some of the protective layer away…not sure but I will try.
I have some noctigons/sinkpads lying around anyway.
The screws for the mounting piece(not sure how this is named) doesn’t fit the threads or maybe the threads are painted…anyone else had this?
You can mount two XM-Ls on one star, but grinding away the space around it will do no good. There is just aluminum under the dielectric layer.
Two XM-Ls at 4.5A will give more output than one, for sure. At 4.5A into one XM-L, you’d be better off with a direct bonded copper star.
I wonder if there would be any differences in heat output:
- 1 x XML driven at 3A
or
- 2 x XML sharing the same star, driven at 3A… so 1.5A each emitter.
Ive noticed that most LED’s seem to run fairly cool until you drive them slightly harder.
There's no aluminum underneath to worry about with a sinkpad/noctigon
That ^^ worked fine, direct drive I think it was around 5.8 amps and made plenty of heat (and a LOT of light). Getting a usable beam pattern with a round flashlight reflector is near impossible but would work great in a floodlight.
What Comfy did should work fine. Now that I think about it, on a regular star it would have heat issues.
Thanks but I probably didnt explain that correctly.
Which would give off more BTU’s? One XML driven at 3A or two XML at 1.5A each. Im guessing the first option, but I havent been able to confirm this.
I would confirm your hypothesis, because actually all power which goes in comes out and we all know that higher driven XMLs loose efficiency(if you imagine the current/lumen diagrams you see that it is not linear, incline decreases)
And so if less light comes out there is more heat but I would not overrate this so much, maybe a few degrees less??
Comfy have you ripped the middle layer a bit away?
Actual heat generated by the emitters would be dependent on the Vf. I’m assuming if current is the same, the pair of emitters would have a lower Vf. Therefore, the pair driven at 1.5A each would generate less heat (and more lumens) than the single emitter at 3A. The difference is relatively minor, but probably measurable.
I cut away the top dielectric layer under the outer halves of the LEDs. So there's a thicker than optimal layer of solder under the outer half that connects direct to the base, still better than nothing. The inner halves are sitting on the normal raised pad.
Thanks for confirming, what I had in mind.
No, the power in and dissipated as heat would be the same (assuming the driver power loss is also included). Say the batteries were at 4.0V: 4V * 3A is the same as 4v * (1.5A + 1.5A).
True, if I was referring to total power in. I was only referring to emitter power dissipation. That was the specific question asked, as any driver power dissipation didn’t seem to be part of the question.
So waste heat scales 1:1 with input power even though light output doesn't?
For the emitter itself, the heat/light ratio increases as total emitter power increases. LEDs are less efficient as the drive current increases.
Assuming an external constant power supply, does anyone know if the ratio of heat output (measured at the thermal pads or mcpcb) to input power is linear with XML? I couldnt find anything to illustrate this in the cree datasheets. I dont care about relative fux ratios.
Hypothetically:
If the emitter outputs 2000 btu at 2A, will it output 3000 btu at 3A? I suspect it will output more than 3000, but its just a hunch from all the mods Ive experimented with. For instance, moderately warm running flashlights driven at 2.5A seems to suddenly run HOT when running at 3A. Im fairly certain this isnt just my perception, but I could be wrong.
Watts is watts… so the amount of power dissipated will scale with current. But, heat radiates proportionally to the FOURTH power of the temperature difference.
Pyro makes a very valid point, but I do not think it addresses the question being asked.
Because VF rises with input current, the resulting power dissipation is not linear.
A hypothetical example:
If = 1A, Vf = 2.9V, P = 2.9W
If = 2A, Vf = 3.1V, P = 6.2W
If = 3A, Vf = 3.3V, P = 9.9W
As you can see, power increased in a non-linear way.
