I really like the performance of the TK-566 and am interested in buying one for my mom who is a bit of a geek when it comes to such things. She's familiar with the dangers of such things and would know better than to look directly into the light. Outdoors in the dark, what is the range of this light? Is it best for up-close only such as checking bank notes? Tomato worms are known to fluoresce under a blacklight and she wants something that could be used to sweep tomato plants after dark looking for them. Which UV lamp would be the best projector?
I have the Tank007 PT30 3W 365nm version, which has 3 of the LEDs of the TK-566 and also a slightly larger reflector. I also have an O-Like 405nm 400mW laser. Even taking off the focusing/collimating lenses on the O-Like (ie RAW diode output), the "UV" of this O-Like causes things to flurorescent more and has a longer throw. The PT30 has a longer throw as compared to the T5, but when you are checking out urine stains on the latrine bowl, the PT30 does not really show this while the T5 shows it clearly (just that you have to bring it really close).
The PT30 has a wee bit of visible dull white output in addition to the UV. If your prescription glasses has UV filtering, no issue. Mine is transition, and it even filters the really powerful non-focused raw output of the O-Like 405nm completely.
But for regular stuff like orange/yellow fluorescent stuff, some types of paper, toilet paper, the O-Like 405nm really causes everything to glow crazily. Focus it correctly, it makes stuff 300m away glow as well, eg a white T-shirt. (that distance is farther than the NOHD, so no danger).
BTW it is not Nichia as mentioned in the video (it was advertised as Nichia on aliexpress). Someone said Edison, whatever. A 3W Nichia NCSU033B one was selling for usd300+ on aliexpress.
380+ nm LEDs are much brighter (and cheaper) than 365nm ones, so if the worms fluorescence under that wavelength it could suffice with a 12 LED UV light from DX for under $5. Even the 5 UV LEDs of the 3-in-1 light is brighter than the TK.
I may buy one if I can find one cheaper than the tank007store...
Yes, I wonder why most other banknotes have so boring (or nonexistant) features.
I managed to take out the front glass cover of the PT30 (it was screwed in very tightly), seems to increase the UV light intensity by a wee bit. I gauged it by bouncing off toilet paper.
Just to give an idea on UV LEDs (3W 365nm Tank007 PT30) vs very very near UV 405nm 400mW....
First one is Tank007 3W 365nm. Second is Laser diode RAW output. The laser diode output is CRAZY, the hotspot is like spread over 2X of what is visible here. As you can see the top of Doraemon's head is fluorescing brightly. I underexposed the LED so as to accomondate the LD output, in real life it is much brighter than this.
Wow, with the plastic lens removed it revealed another band of details (the orange ones). For my PT30 the lens is glass, it just cuts maybe 5-10% of the UV intensity...taking it out does not reveal more details.
The notes that don’t have the UV so visible are harder to copy. Also you might not be using the correct light to see the marks as it is quite visible on all of the lights except the TK-566. It’s all about using the right wavelength and not shining a tons of blue/violet light at it like most lights did. I think they are still too much in the visible spectrum.
