Response from Zebralight is Nyogel.
We now have high CRI XM-L2, and XP-G2s available
XM-L2 Bare S6, 7D3 (2900K) 90 min CRI and
XP-G2 Bare Q2, 7C (2900K) 90 min CRI
Nitecore SRT6 & 7 in stock in Black and Gray. Promotions still active with codes: "SRT7" or "SRT6" for respective products.
:party:
YAYY!!
Sweet emitters. Great prices!
High CRI order placed!
Should not the XP-G2 be labeled (3000K), like the XM-L2?
The XP-G2 is in the E7 group, which is probably the same group as the 3000K XM-L2 (if not Z7). Or am I missing something.
Thanks for getting these in stock.
Upon further reflection, the emitters are likely closer to a 2900k rating.
Hm…. Should I get an EA4W, or EA8 NW for my dad?
I’m sure he’d appreciate the extra run time, not to mention the extra throw would help make this his new light that he can use for everything.
What does everybody else think? A 52 year old man who likes fish, fishing and the occasional yard work would an EA4 suit him better, or an EA8? Right now he’s using a silly incan handheld spotlight which has laughable output, but serious throw to lumen ratio. I’m leaning more towards the EA8 since it has more throw.
EA8
Calvin you should change the description of the high cri XML2 as its much dimmer than the other bins maybe 600lumen max instead of 1000lumen…
High CRI XPG2 and XML2 in my shopping cart.
We just received some info on the SRT3 and SRT 5. Both flashlights will contain red+blue LEDs. The SRT3 will be able to take a single (R)CR123 or AA/14500/LifePO4 with an extension tube. The SRT 5 will use 2 x (R)CR123 or 1 x 18650. We're looking at max outputs of 550 and 750 lumens for each respective flashlight.
:D
just commented on your FB post
WHEN??
Nice!
We're looking for someone to do a test/review of these direct thermal copper XM-L2 U2 1Cs, normally I'd just pick someone but I'm short on time today so either recommend yourself or someone else and convince me of your ability to do a comprehensive and fair overview. Thanks in advance for your help guys!
Me Me!
I recommend Tom E too as we can compare our results.
I already have several of your emitters on copper to compare with. Generally my test results seem to compare to others.
i second relic38
match would be my #1 choice... and myself of course... but if you want some actual results besides "it fit right in to my c108", then id pick match
Holy crap that is sexy.
I recommend Match!
Pre mounted 5c1’s would be awesome too.
Any rumors on u3 bin xml2?
I would have recommended match, but I was under the impression he has ‘retired’ from testing emitters. That status might have changed since his last few posts though.
