Thanks Relic. I’ve been waiting for this. Since you’ve been tardy in your “how to” postings I had to figure it out myself. Fortunately, I seem to have done it correctly.
A couple of times I folded a piece of braid in half, soldered the vee to the base and the two ends on opposite sides of the spring at the top. I don’t know if it helps, but it can’t hurt.
After an XM-L2 or XP-G2 copper star upgrade, I put a lot in the light box, remove the tailcap, jumper the neg. batt to the host with a heavy gauge wire, check the reading. Then, assemble it with the stock tailcap, take a reading. Most lights of single cell, nanjg driver of 3.5A or higher variety will read lower with the stock tailcap and will benefit in lumens from this mod. Usually I get almost all the lumens back from the mod.
Regarding heat reduction, potentially. To many factors to be sure. One thing is for sure, there is less heat in the tailcap end which increases the chances of that energy being dissipated by the emitter.
Well it all depends on the light and the build, I believe, ex: 3.5A vs. 4.5A for example - greater loss in the 4.5A build. In a SS T13, I saw no loss, but that could be because how the buck driver works - I didn't do the copper braid because I saw no benefit, but maybe it would increase the battery runtime.
Update 06/25: Last night I saw just under 1,100 lumens with a suspect broken copper braid tailcap (didn't confirm yet), replaced with a good wired tailcap and got 1,234 lumens, so on this C8 heavily modded light, it was about 12%.
Thanks for this. I tried it for the first time today, and I let the solder creep too far along the wick, which resulted in the spring being much less springy.
I liked using nail clippers to trim the wick. It cut the wick without fraying and cleanly trimmed the wick flush with the top of the spring.
I've got a couple of broken solder braids, but think it's always because of solder creeping up the braid, leaving a small length of flexible section, then it easily tears apart with compression of the spring. I've been soaking the braid pieces in acetone now to fully remove the flux, then isopropyl to clean, then don't keep the iron on the braid ends too long.
In the light I just built for O-L’s challenge the Q-Lite 3.04A driver I used had the short hard spring. I replaced it with a steel spring, upside down. When my AW IMR14500 came in I was surprised at the low amp reading I got, so I soldered a 22ga copper wire inside the spring and found another 670mA of power! So now it’s running 2.82A and all is well!
I usually go through the center of the spring and solder the wire to the contact board right in the middle, inside the circle of the spring. Then I solder the top of the wire inside the top hoop, so that no wire is above the coil. Not really necessary to leave any slack in the wire/braid as the spring is as long as it’s going to get, it will only compress. That being said, I do like to add a bit of a coil to the copper wire just in case.
Thanks for the pics relic, whether or not we do it the same way the end result is more Powah!!
Edit: It’s not necessary to rush out and buy wick braid material. The copper braid around a television cable that works as a ground will work just fine, or a thin copper wire with or without the insulation. Probably the determining factor is figuring out just how much compression is on that particular spring when the light is assembled. If the spring isn’t getting squashed down very far, a simple wire works just fine.
Great write-up, relic. It's amazing what this can do to some lights, even with just wire looped around a few times. Every Solarforce host I've done this to measures a few more mA.
I prefer using silicone wire instead of copper braid though, since the braids that I previously did started tearing apart…I might’ve done something wrong :bigsmile:
thx that’s damn good results. Are those results only expected when running higher currents say 3.5A and above? And what would you attribute the gain to? Copper being a better conductor? the flat braid being the best pathway, and also bypassing the spring which might behave like a coil? or combination of both?
There are so many to choose from, do you have a link to that one?
