I just find this charger in fasttech, I have some 18650 Samsung that can be charged to 4.35volts to a full charge, I will try…
https://www.fasttech.com/products/1421/10000969/1285301-2013
I am working on a review of it and it does have a few problems.
good to know,waiting for you review
They have been on FT for awhile now. The first I received seemed to cut off at 4.29V.
The next was a bit better, around 4.32 I think.
ups…
I have Sanyo 2800mAh batteries that are also 4,35V but I’ll keep charging them on regular chargers. They need to be ready (charged) at all times and I believe they will have longer lifespan mostly waiting charged to 4,2V than a regular 4,2V cells would.
did you post the review? can you tell about the problem? they are now grouping them together with 2 batteries for $20; seems like a good deal
I don’t think the deal with two Panasonic 3400mAh batteries will be such a good deal if they are rated at 4.2v! Mind you, a year ago it would have been worth it if you simply chucked the charger away!
Sanyo UR18650ZT 2800mAh are 4.30V cells, not 4.35V. You may be thinking of Sanyo UR18650ZTA 3000mAh cells; they are 4.35V cells.
I like to try it. Less than a $10 price tag looks fine to me.
This is the HKJ’s review
Heseny HXY-18650-2A (4.35 volt) [image] [image] This is a 4.35 volt charger, i.e. it cannot be used for the normal LiIon batteries, but only 4.35 volt cells like LG 18650 D1 3000mAh (Pink) and Sanyo UR18650ZTA 3000mAh (Magenta). [image] I bought it from Fasttech and it was shipped in the usual envelope. [image] Only contents of the box was the charger, nothing else. [image] Specifications on the back says universal voltage and 1A charge current. [image] [image] At t…
