tom, I have used that driver before, it is a good one imo, infact I ordered two more last night for a couple of convoy l2 builds, the last one I received looks nothing like the picture on that page……I’m hoping these next twp will be identical to the first o recieved or I’m in the cacky but I will report back.
fwiw, I used it in an mt-g2 build and I couldn’t be happier with the outcome, really good mode spread and no whining.
All of these threads on modded BTU’s are really making me want to send out mine or order a new one for moding by one of the amazing talents on this forum! Tom, amazing work as always sir!
everyone needs to own one of these, whether its the stock form, dry driver, tom e upgraded model etc… a great light, proper heatsinking and it doubles as a beating stick if needed because its large.
and the modded tom e version costs about as much as a new tk75 and is better
i guess better is a subjective term and i will catch flak from the tk75 lovers… hey! if you have any doubts just buy both LOL
I have a TK75 which I am very fond of but I also know what Tom can do with a shocker so I totally understand what you are saying. I took your advice anyway and got me a shocker too!
you bought a shocker too? im a bit surprised. arent the shocker’s beam very similiar to the tk75? were you thinking of modding your shocker or something?
Took me shocker for a walk last night, at the back of my estate there is an old Raf airfiled, which now is civvy owned and farmland, this has a cycle/path running through center of it, so used me light to shine up woods, houses, jcb/crane that are ripping up old tarmac, the 2 night watch me were not impressed, looking for a car trying to steal the jcb/crane, must admit I did tease them a bit they though there was a car about, even though light was waaaaay too much for a car, was well funny ha ha.
It’s bloody heavy though, and very unbalanced, mine did not have the auto step down after 3 minutes, am I right in assuming it’s not putting out enough light to get hot enough for this function to kick in ?, I am using my AW cells in this light last night, I think it doesn’t need 4 settings, just a higher low them med and turbo, would like to have seen a strobe mode though.
tabs
Your not mistaken, the difference from 3K to 2K lumens its not noticeable if its not instant 3000 to 2000, its getting lower then 3K slowly, not all of a sudden.
The beam is similar. Both lights are very powerful flooders with great throw too. My brother and I were just out playing with them last night. The TK75 is a flood monster that still throws well. The shocker is a floody light also but throws with a TN31 even in stock form. His modded one just accentuates those traits. As for getting the shocker modded, I more than likely will get both lights done. I personally think they complment each other well.
Thinking about it now, you must be right, I just assumed the cells weren’t fully charged and that light was just getting flat, I did notice after a while it was not as bright, I just mistakenly it seems assumed the ramp down was instant.
Thanks for clearing that up for me, I’m off on the same torch walk tonight, 2nd best hobby I’ve ever had this is, I like RC flying, but always get things stuck up trees ha ha.
tabs
I ordered some new high-discharge cells from FT for this, just to see if I can get a little more out of it. Using my dead BTU original driver, I can get over 5A from the Sanyo ZT cells. I am using the DRY driver right now, which I’m not really a fan of.
tkmclay, I could do the XM-L2 mod, I did it to mine. Only issue is timing. I cannot say when i could do it though. PM me if you are interested in having it done in the next month or two.
What batts? I don't understand -- using a dead BTU driver you get over 5 amps?? I'm confused... Did you do any lumens/throw measurements? Assume you got XM-L2's on copper?
Ohh - I'm all confused... But interested if he was able to re-produce what I seen. Just haven't had a chance yet to mod the next Shocker same way to see if it can be re-produced... Really would have been better for me to do a lot more testing/experimentation with it while I still had it...
Tom E, OK I’ll try to de-confuse things a bit.
Regarding the new cells, I ordered higher discharge rate cells “(Pana PDs)”:https://www.fasttech.com/products/1233700 to see if they can hold a better voltage under load than the Sanyo ZTs. Fasttech sent them by SingPost, so I hope to see them before August…
Regarding my BTU driver, I fried it a while ago and it turned into a single-mode ‘driver’ that delivers a lot of current (over 5A). I decided to swap to a DRY driver, which is not delivering nearly as much current.
I still have the issue of lower output than your tested BTUs (stock and modded) at the same drive current. I am not trying to address that at the moment. Right now, I want to overcome the potential issue I have of lower drive current when running on cells. That is what the new cells are for.
I may also take a closer look at the DRY driver for any resistance mods that can be done.
ohaya, I meant the driver is now a glorified piece of wire.
I think I reversed the polarity on it and that caused it to release some magic smoke. I still have it intact in a bin of replaced drivers, but there’s no physical sign of damage that I can see.
simplec6, the easiest way to lap a star is to use gradually finer grits of sandpaper on a flat surface. For each cycle, sand the bottom of the star until it has a uniform finish. Then repeat with the next finer paper. I finish off with a mirror-like finish at 2000 grit. Others continue to 2500 grit.
Based on this result, I think 2000 grit is acceptable.
