great job and shots
I ordered 1 too with the 5$ GC, the heat dissipation looks poor the 5 cent coin is copper only externally, inside as you can see sanding is steel, that will not help thermal dissipation right?
Ever wondered how is the thermal conductivity of the nordic gold, (10, 20, 50 cents) is 89% Al and 5% Copper 5%zn and 1% stain so in the paper should be good but how in fact mixing and shaking all? anyone know that?
I didn't know that 5 euro cent coins are not copper before sanding them, but decided to continue because steel is still 2000x better than air. ;) (and "only" 4x worse than aluminum / 7x worse than copper)
[quote=MixoMaxo]
Btw destroy the money is illegal XD
[/quote]
Thank you very much for welcoming and your answer. This flashlight is cheaper than money - looks like the best deal in town. Will be acquiring it shortly along with a 26650 battery. Which one would you recommend? My usage pattern would be turning it on only on occasion underwater - looking into caves while spearfishing. 10 minutes a day at most. So one battery can last me for at least two weeks without a need of a charger.
Unprotected cells are usually better for diving (they don't shut down suddenly when running low on power, just dim slowly), but as you are just looking into caves, that shouldn't matter so much.. And protected ones are safer! You can't ruin the cell by overdischarge and protection helps in case of short circuit (or overcharge caused by faulty charger).
Those Trustfires can be bought also from DX (about $2 more expensive than FT, but if you want them to the same package..)
In that ‘TrustFire’ link you gave me there are two options: red ones unprotected and black ones - protected. Red ones have three reviews, black ones - none. I did some search and some say that the red ones are protected, but it does not say it on the battery. On the black one it does. I assume you are using the red ones. Are you sure they are protected?
Thanks again, now I am all set! Already ordered the flashlight, battery and charger will follow. In two month will be going to do lots of spearfishing and will post the link of the flashlight operating under water - I have a mask-mounted HD Pro camera. Will try to take it to 25-30 meters since I can not freedive deeper.
I bought one of these and the lens was glass, ordered another and it was plastic both from the same seller.
I’ve since been refunded on it but would like to find a glass lens for it like the first one has.
offroad… did you disassemble your light? Did you measure the diameter and thickness of the plastic lens? If so, would you please advise dimensions you got.
Did you measure the thickness of the glass lens that you received? Did you try to put the glass lens into the light that original came with a plastic lens?
I’m concerned that - even if we find a glass lens of sufficient thickness - these lights with plastic lenses may have been customized to take a thin plastic lens but not a thicker glass lens.
I’ll measure both and post the dimensions this evening if I’m not home too late.
Didn’t compare them side by side, but as I remember the plastic one was about as thick but the weight and feel gave away the fact its plastic not glass.
Head’s and bodies seem the same to me so I doubt there has been any change on it.
The auction I purchased both on said the lens was glass and indeed the first one I received was.
That’s interesting. I would have guessed that the plastic lens was thinner. I’m starting to wonder now if it’s worth giving it a try. I’ve got some time to think about it - I’m not going to be diving until early November, at which time I’d take it to about 80 or 90 feet - day-afer-day for 10 days. That should give it a chance to crack!
I’m sure you searched DX - no lenses at this size.
You probably know about this, but just in case, there’s someone with a site specializing in flashlight lenses:
The stock lenses are cheap, but our lights might require a custom lens - I haven’t had time to check the site carefully.
I’ve contacted all fleabay sellers of this light, and also searched elsewhere but can’t find a replacement glass lens.
If you want glass, most likely the only solution is having one custom cut.
Probably a non-issue though, as I posted in the other forum and found someone who has been diving with these lights with acrylic and glass versions with no issues.
He has a blog (scroll down), where he shows how to convert these from a dive light to an video light.
I may do that with one or two more of them.
Meanwhile, I did the thermal mod shown earlier on one of mine, upgraded to a XM-L2 NW emitter and swapped the wires for 22ga silicone. Will do the other after some comparisons.
