Thank you very much for welcoming and your answer. This flashlight is cheaper than money - looks like the best deal in town. Will be acquiring it shortly along with a 26650 battery. Which one would you recommend? My usage pattern would be turning it on only on occasion underwater - looking into caves while spearfishing. 10 minutes a day at most. So one battery can last me for at least two weeks without a need of a charger.
Unprotected cells are usually better for diving (they don't shut down suddenly when running low on power, just dim slowly), but as you are just looking into caves, that shouldn't matter so much.. And protected ones are safer! You can't ruin the cell by overdischarge and protection helps in case of short circuit (or overcharge caused by faulty charger).
Those Trustfires can be bought also from DX (about $2 more expensive than FT, but if you want them to the same package..)
In that ‘TrustFire’ link you gave me there are two options: red ones unprotected and black ones - protected. Red ones have three reviews, black ones - none. I did some search and some say that the red ones are protected, but it does not say it on the battery. On the black one it does. I assume you are using the red ones. Are you sure they are protected?
Thanks again, now I am all set! Already ordered the flashlight, battery and charger will follow. In two month will be going to do lots of spearfishing and will post the link of the flashlight operating under water - I have a mask-mounted HD Pro camera. Will try to take it to 25-30 meters since I can not freedive deeper.
I bought one of these and the lens was glass, ordered another and it was plastic both from the same seller.
I’ve since been refunded on it but would like to find a glass lens for it like the first one has.
offroad… did you disassemble your light? Did you measure the diameter and thickness of the plastic lens? If so, would you please advise dimensions you got.
Did you measure the thickness of the glass lens that you received? Did you try to put the glass lens into the light that original came with a plastic lens?
I’m concerned that - even if we find a glass lens of sufficient thickness - these lights with plastic lenses may have been customized to take a thin plastic lens but not a thicker glass lens.
I’ll measure both and post the dimensions this evening if I’m not home too late.
Didn’t compare them side by side, but as I remember the plastic one was about as thick but the weight and feel gave away the fact its plastic not glass.
Head’s and bodies seem the same to me so I doubt there has been any change on it.
The auction I purchased both on said the lens was glass and indeed the first one I received was.
That’s interesting. I would have guessed that the plastic lens was thinner. I’m starting to wonder now if it’s worth giving it a try. I’ve got some time to think about it - I’m not going to be diving until early November, at which time I’d take it to about 80 or 90 feet - day-afer-day for 10 days. That should give it a chance to crack!
I’m sure you searched DX - no lenses at this size.
You probably know about this, but just in case, there’s someone with a site specializing in flashlight lenses:
The stock lenses are cheap, but our lights might require a custom lens - I haven’t had time to check the site carefully.
I’ve contacted all fleabay sellers of this light, and also searched elsewhere but can’t find a replacement glass lens.
If you want glass, most likely the only solution is having one custom cut.
Probably a non-issue though, as I posted in the other forum and found someone who has been diving with these lights with acrylic and glass versions with no issues.
He has a blog (scroll down), where he shows how to convert these from a dive light to an video light.
I may do that with one or two more of them.
Meanwhile, I did the thermal mod shown earlier on one of mine, upgraded to a XM-L2 NW emitter and swapped the wires for 22ga silicone. Will do the other after some comparisons.
Looks cool, but will have thermal problems, sooner or later. I'd suggest using a thicker (& round) piece of metal and making sure it is fit to body to ensure proper thermal transfer.
[quote=offroad]
Meanwhile, I did the thermal mod shown earlier on one of mine, upgraded to a "XM-L2 NW":http://intl-outdoor.com/noctigon-xm20-mcpcb-cree-xml2-t6-3a-led-p-753.html emitter and swapped the wires for 22ga silicone. Will do the other after some comparisons.
[/quote]
Sounds great! Looking forward to seeing the comparisons. :)
I thought the same about thermal transfer, and also wondered if using something reflective could improve output.
If its flat there shouldn’t be a hot spot, so fine for video.
Side by side, my XM-L2 T6 3A version appears just a bit brighter than the stock XM-L U2.
The NW tint also renders outdoor colors better, so hopefully would also bring out truer colors during a dive.
Run Time XM-L2 High Mode - TF 26650 (Sink Test)
30min - 3.76v
60min - 3.58v
90min - 3.55v
120min - 3.41v
150min - 2.97v
At 120min and 3.41v I was surprised to find there was little difference in brightness (wall / ceiling bounce test) between the XM-L2 light on the 26650, and the XM-L light on a fully charged 18650 (my other 26650 was returned to FT for a Protection Circuit issue)
At 150min and 2.97v, the brightness was way down but still useable.
(I wouldn’t normally run the battery this low, but on a dive light its nice to know what to expect)
I like these lights and when taking the dog for her evening walk, I’m frequently choosing it over one of my P60 lights.
It compares well enough in brightness even to a couple I have with 3.0a current draws, and the beam throws much better on our large property (sorry no beam shots).
The current draw vs run time is about perfect for my needs, they are bright and will easily fit in a BC pocket.
Thanks to”the” for the thread, and for giving me advice on my first mod.
You might try contacting the seller about the spring and parts. I bought a really cheap light from Ebay seller awhile ago, and the tailcap switch stopped clicking/working. I emailed them about the problem, and, surprisingly, they sent me a complete replacement tailcap. Maybe your seller will be able to provide those?
