Since this is a large piece, you could solder one end and then put that end in a little water and solder the other end. If the torch can get the one end hot quickly enough, you can solder one end, while the other end is in water. Kind of like plumbers that have to solder a copper pipe while there's water in the pipe. I have also done it by sitting one end on a folded up, soaking wet towel.
Happy Canada Day!
I have added some more updates from the weekend. Some very good progress I’d say. Hopefully I will get this done soon because I’ll have no time next weekend and then this contest wraps up.
Glad you like it.
That’s just the one you can see. They will not be there long. Dish soap and warm water, followed by a good rinse and some compressed air. Good as new.
When you finish this light it will make all other lights look outdated. Love the triple emitter set up. Whens the lens due in?
On a side note some Aussie members may remember this. I think it was Street Machine mag that had a cartoon in it called Plankenum (not sure on the spelling) and his extractors on his ute from memory were made from plumbing fittings.
I was hoping to get the lenses this week, early. Coming from flashlightlens.com ordered early last week. Tracking isn’t showing anything yet, which is very strange. My IS packages usually take 6-7 days, tops. Not looking good…
Thanks for the clarification, R86. I was sure I read somewhere they were 80CRI.
Very creative ways to solve design problems. When it's done I would love to know/see what tools were necessary to accomplish all of this. For example, what did you use to cut the half inch copper pipe lengthwise?
Dremel with a cutoff wheel, actually many cutoff wheels
So yesterday I got the emitters mounted in the head. Today I quickly wired them. I just had to see how the beam was going to look with three of the warmer tint T5 5C1 emitters. It’s a beauty. With no lens or bezel I get about 1800 steady lumens at 6A (2A/emitter). I will settle on 2.8A/emitter once the driver is build. I hope to get 1800-1900 lumens OTF once the bezel and lens are in place. My XM-L2 U2 1C SRK is going to be taking a back seat once this thing is built. Tint wins over lumens.
