Nice one pyro! so, how many of those 150W emitters are you putting in this light?
littelfuse_discrete_mosfets_n-channel_trench_gate_ixtz550n055t2_datasheet.pdf.pdf
206.25 KB
Probably just one, but might be driven at 300 watts or so… J)
At 10 amps, the MOSFET is only dropping 1/4 watt of heat. It has a 0.002 ohm on resistance.
I have no idea what you're saying, but I'm pretty sure it's awesome.
When I saw the deans plugs I could estimate the scale. Remote barbeque lighter?
What's going to be driven with this monsterfet?
The board is 2 x 2.5” and used through hole parts since I had them sitting around. If I do it over again, it will be surface mount and much smaller (and with lower capacity FETs). I’d probably also put the high-current gate driver on the second PWM channel/FET.
Beautiful!
J) <= that emoticon pretty much sums up my feelings while reading the specs.
I’m looking forward to your build!
That’s exactly how I feel as well! :bigsmile:
I you can spare couple of W you could use peltier cooler J)
Peltier coolers are a joke. They take over 20 watts of power to produce 1 watt of cooling… and you have to get rid of the 19 watts of heat somehow…
Awesome and powerful. Whether a 75x75mm CPU fan cooler can handle the heat of the LED and the driver. It should produce a lot………………of light.
hm, didn’t know that.
That is some coolness right there, TP!! >)
Sirius9:I you can spare couple of W you could use peltier cooler J)
That's easy. Just use a second TEC to cool the first one. :party:
relic38:Nice one pyro! so, how many of those 150W emitters are you putting in this light?
MOSFET pr0n:
206.25 KB
RDSon = 0.001 Ohm
This one is in a slightly different class though, the package is somewhat large for your board
MOSFET pr0n:
http://ixapps.ixys.com/DataSheet/DS100243(IXTZ550N055T2).pdf
RDSon = 0.001 Ohm
27 bucks a pop… and you have to buy 9 of them. Also, they conveniently don’t spec some important specs…
Not sure about missing specs being convenient for anyone… which missing specs should be there?
I have no idea what you’re saying, but I’m pretty sure it’s awesome.
Me as well. It sounds like your light may be used on a locomotive?
nice! 300W=around 12000 lumens ? you win the lumen part of the contest.
More like over 20,000 lumens… You get well over 15,000 lumens at 150 watts.
