(Updated July 16) Review/Test: Illumination Supply Direct-Bonded 16mm Copper Star with Cree XM-L2 U2 1C
44 posts / 0 new
relic38
relic38's picture
Last seen: 4 years 11 months ago
Reviewer's Overall Rating: Review Incomplete
 [Review subject photo goes here]
Summary:
Diameter 16mm
Thickness1.5mm
MaterialCopper with upper dielectric, lower nickel plating
LED Type: Cree XM-L2, Flux Bin U2, Chromacity Bin 1C
Date Ordered:Review sample provided by Illumination Supply
Pros:
Cons:
Features / Value: TBD
Design / Build Quality: TBD
Overview
The Illumination Supply Direct Copper Bond (DCB) emitter stars from Illumination Supply offer improved thermal transfer characteristics over traditional aluminum stars with a dielectric layer.  When attempting to push an emitter to extreme power levels, heat begins to negate any potential gains.  By bonding the emitter thermal pad directly to the star base material, heat is transferred to the star and on to the heatsink at a much faster rate.  The result is a cooler emitter die at the same current, therefore more photons out the front.
Setup
First, a little bit on the setup.  The emitter is mounted to a 900g aluminum heatsink with large fins on the back.  A fan is blowing on the back to maintain as close to an ideal heatsink as possible.  This setup is close enough, but not perfect.
In addition to Luminous Flux (lumens), measurements of Emitter Current (IF), Emitter Voltage (Vf), Emitter Temperature, and Heatsink Temperature were taken.  Measurements were taken at 0.2A increments from 0.2A to 6.2A.
In this first image, you can see where Vf and Emitter Temperature were measured.
I used duplicate wires to feed back to the voltmeter; no wire drop was measured.  The goal was to measure the voltage drop across the star being tested.
I used a standard thermocouple glued to the edge of the emitter, as per recommendations found in a Cree app note (a reference link will be provided).
Emitter Closeup
I will note that my initial naked-eye evaluation of the emitter placement did not show any misalignment, there does appear to be a slight misalignment in the emitter placement in this macro image.  I will confirm this with an even closer macro before concluding anything.
This second shot shows the three meters used to capture Emitter Temperature (Vichy VC99), If (Metex M-3800), and Vf (Metex M-3800).
Meters
The Heatsink Temperature was measured right under the emitter placement, between the heatsink fins.  This measurement was taken with an IR temperature probe (the heatsink is anodized). In other words, as close as I can get to the base of the star without needing to move the setup between measurements.
Here is the complete setup (power supply is out of frame to the left)
full setup
Closeup of heatsink in position.
setup heatsink
And finally, the light meter:
light meter
Performance Tests
The first test is with the emitter/star in stock form, as shipped.
Stock
Test Results Data:
IS DCB 16mm Star with XM-L2 U2 1C Emitter (Stock)
IfVfPledLumensTledThs
0.22.770.559823.021.4
0.42.851.1418724.021.4
0.62.911.7527824.021.4
0.82.962.3736026.021.4
1.03.013.0144027.021.4
1.23.053.6651628.021.4
1.43.104.3459329.021.6
1.63.135.0166330.021.6
1.83.175.7173032.021.6
2.03.206.4079633.021.3
2.23.237.1185734.021.8
2.43.267.8291836.022.0
2.63.288.5397337.022.2
2.83.319.27102939.022.6
3.03.3410.02108041.022.8
3.23.3610.75113142.023.0
3.43.3811.49117644.023.2
3.63.4112.28122145.023.6
3.83.4313.03126447.024.0
4.03.4513.80130448.024.2
4.23.4814.62134250.024.4
4.43.4915.36137551.024.8
4.63.5116.15140753.025.0
4.83.5416.99143855.025.2
5.03.5517.75146457.025.4
5.23.5718.56148959.025.8
5.43.6019.44153761.026.4
5.63.6120.22156063.026.8
5.83.6221.00156766.027.2
6.03.6621.96158268.027.4
6.23.6822.82159069.027.6
It is still early, but this data looks promising, although slightly off the results found by Match on a SinkPAD.  My setup is not calibrated to his, so there could be some variation.  Once I get to the stage The star appears to be doing its job at getting the heat away from the emitter and keeping it as cool as possible.
Once the test was complete and things cooled down to room temperature again, I retested the emitter at 0.4A to look for signs of fatigue or wear.  The results were identical to the first pass.  I will note that the emitter was not run at 6.2A for more than a minute.
Next test is with the star lapped flat.  This took a while, as the bottom is not already flat, it is slightly concave.  This image was after lapping for a while with 2000 grit sandpaper.
IS-DCB Lapping
I move to 400 grit, lap it flat, then proceed to lap down to 2000 grit for a smooth finish.
IS-DCB Lapped
Test Results Data:
IS DCB 16mm Star with XM-L2 U2 1C Emitter (Lapped)
0.22.760.559423.021.6
0.42.851.1418424.021.6
0.62.911.7526825.021.6
0.82.962.3735126.021.6
1.03.013.0143127.022.0
1.23.053.6650928.022.2
1.43.094.3357729.022.0
1.63.135.0164930.022.0
1.83.165.6971831.022.2
2.03.206.4078132.022.6
2.23.237.1184133.022.6
2.43.257.8089934.022.8
2.63.288.5395735.022.8
2.83.319.27101037.022.8
3.03.339.99106238.023.2
3.23.3610.75111340.023.4
3.43.3911.53115941.023.4
3.63.4112.28120343.023.6
3.83.4313.03124644.023.8
4.03.4513.80128745.024.2
4.23.4714.57132547.024.4
4.43.4915.36136048.024.6
4.63.5216.19139150.024.8
4.83.5416.99142452.025.0
5.03.5617.80145253.025.0
5.23.5818.62147555.025.6
5.43.6019.44152256.025.8
5.63.6220.27154558.026.0
5.83.6421.11156060.026.0
6.03.6621.96157562.026.4
6.23.6822.82159064.026.6
No significant change in output (virtually identical), and a marginal change in emitter temperature. The temperature probe remained in the same place between tests.
At this point I desolder the emitter to move it to a different star for comparative testing, and I notice the thermal pad was not completely soldered down:
IS-DCB solder
The solder paste used was an insufficient quantity to fill the pad gap, and it did not bond well with the base.  Instead of moving on, I decided to reflow the emitter again and retest.
IS-DCB Reflowed
Test Results Data:
IS DCB 16mm Star with XM-L2 U2 1C Emitter (Reflowed)
0.22.760.559423.021.4
0.42.851.1418424.021.4
0.62.911.7526725.021.4
0.82.972.3835126.021.4
1.03.023.0242827.021.6
1.23.073.6850428.021.4
1.43.114.3557529.021.6
1.63.155.0464930.021.6
1.83.195.7471631.021.8
2.03.236.4678132.022.2
2.23.267.1784334.022.4
2.43.297.9090235.022.4
2.63.328.6396236.022.6
2.83.359.38102037.022.8
3.03.3810.14107538.023.2
3.23.4110.91112839.023.4
3.43.4411.70118140.023.4
3.63.4712.49122842.023.4
3.83.4913.26127842.023.6
4.03.5214.08132244.024.0
4.23.5414.87136645.024.2
4.43.5715.71141046.024.6
4.63.5916.51145047.024.6
4.83.6217.38149048.024.8
5.03.6418.20155250.025.2
5.23.6719.08159051.025.4
5.43.6919.93162752.025.4
5.63.7120.78166453.025.6
5.83.7421.69169454.026.0
6.03.7622.56172455.026.2
6.23.7923.50175456.026.6
Much better.  Over 150 lumens gained.  Emitter temperature is lower but not dramatically so.  I suspect that each time I apply the probe, I could get different thermal contact and this will skew that data.
Here is the solder bond from that test.  Much better, but it appears the base is still resisting fresh solder paste.  There is a very small gap between the emitter and the base, which I have seen on other DCB stars.  This is just one possibility.
IS-DCB reflow 2
One curious change from the previous two tests is the change in emitter Vf.  It jumped by about 100mV.  I have no explanation for this change.  The reflow was not done to the Cree recommended temperature curve (realistically, none of us have the equipment for that), but I would not have expected this.  Another possibility is a less secure solder joint that I didn't notice.  Just possibilities, this is as yet unexplained.  I'll return the emitter to this star and recheck Vf again at some point.
Comparison to Other Emitter Stars
I have also tested Noctigon, SinkPAD, and aluminum 16mm stars with the same emitter.  The results are very comparable, when comparing apples to apples (properly mounted emitters on lapped stars). Since I do not have pre-mounted emitter products available for the competitor stars, I am comparing the lapped reflowed data (what I consider apples to apples).
compared
Note: This particular aluminum star did not perform well.  I have another that I want to try at some point.
Closeup of 5.0A to 6.2A for the three leaders:
Compare closeup
These results (3.7% variance) are probably well within my measurement tolerance.  I would give a very slight edge to the SinkPAD and Noctigon, but it's so minor that it is probably unnoticeable in all but calibrated equipment.  In practical use, these three DCB stars seem to give comparable results.
Dimensions
  • Thickness: 1.57mm
  • Diameter: 16.04mm
  • Widest diameter: 16.91mm, stamp edges may need minor trimming in small pills
Conclusions
I have no conclusions at this point.  The IS-DCB star definitely does perform much better than an aluminum star. The emitter is definitely capable of serious light output. However, I do have some issues to resolve before I can recommend this product as a whole.
First, and most glaring, would be the possibility of improperly reflowed emitters.  The poor solder bond could be a singular faulty unit, or a systemic problem with production.  Calvin at Illumination Supply is looking into the stock to see if more units have similar problems.
The second, apparently minor, issue is the non-flat base.  This didn't show a significant problem in the comparative tests, but the reflow issue may have masked it. This problem is resolved with a minute or two of lapping.  Because of this, I'm not concerned about this one.
More to come as we get to the bottom of the reflowing issue.
Thanks for reading! searchID8934
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
Edited by: relic38 on 07/18/2013 - 23:05
Bort
Bort's picture
Last seen: 12 hours 12 min ago
Thanks for doing this test, its looking good so far!
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
ohaya
Last seen: 11 months 2 weeks ago
Hi relic,
I’m really looking forward to the comparisons you listed!
Jim
MRsDNF
MRsDNF's picture
Thanks relic38. Looking forward to the rest.
tivo532
tivo532's picture
Last seen: 7 years 12 months ago
Very useful info. A++++ Subscribed!
eebowler
eebowler's picture
Last seen: 1 month 20 hours ago
Thanks relic!
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
djozz
djozz's picture
Last seen: 20 hours 26 min ago
These measurements look very well done, thanks for doing the job! Apart from the performance of the IS copper board, it gives some nice information about the XM-L2 emitter as well. I am looking forward to the pictures of the light measurement set-up, and to the rest of the tests.
bdiddle
Last seen: 11 months 1 week ago
I would have thought it would have scaled better…..
Thanks!
Newb
Hikelite
Last seen: 5 hours 42 min ago
The lumens are a bit under, 1080lumens at 3A for the XM-L2 U2.
Tom E
Tom E's picture
+1 - Nice Job! Who's missing Match? I'm also interested in seeing how you did the lumens measurements.
relic38
relic38's picture
I noticed that too, and I believe part of it is due to the emitter no longer at 25C when at those drive currents. The rest may be tolerances in my measurement equipment. I’m sure Cree are slightly better set up than I. Smile
Welcome the night.
FlashPilot
FlashPilot's picture
Last seen: 4 hours 21 min ago
Great job relic! Regardless of any minor inaccuracies in your calibration, your direct comparisons should eek out any differences between test samples. I wonder how an aluminum sinkpad would fare since they are the same in construction as their copper counterparts (direct thermal path).
Do you plan on removing and reflowing the same emitter to each board you test?
relic38
relic38's picture
Thanks FP. I am planning to reflow the same emitter in each test. I am aware that repeated reflow cycles are not advised my Cree, however I am confident that the stress this introduces will create less variation than trying to do the test with different emitters. I also have full control of max reflow temperature so I do not overheat the emitter any more than I have to.
I do not have an aluminum SinkPAD. Maybe I should fill out that survey…
Welcome the night.
Calmaja
Last seen: 3 years 4 months ago
Thanks very much Relic for the hard work.
I’m still missing Match though, I believe he’s part of members that give some inspiration for many others here. Will be glad if he back, that’s not mean he have to do some testing :bigsmile:
ImA4Wheelr
Great info and report. Thank you.
Just don’t plot lumens/watt, that might depress me.
FlashPilot
My thoughts exactly about production variations between emitters. You’ll notice a sudden plunge in luminosity should your emitter start to fail after a reflow and turn-on readings should all be close.
The survey is how I got my AL sinkpads. Just a hunch, but I bet they will perform far better than most people would expect.
Tom E
Tom E's picture
 The Vf and lumens are consistently lower than Match's tests on a SinkPAD - I think he used a U2 1C as well. Now this difference isn't a bad thing at all - just interesting to note. More important is it's in the neighborhood and your lumens curve looks really, really good and match's up with Match's, accept for that hitch at 5.2-5.4A. So could be just the measurements/calibration, emitter differences, or the copper star is that much different from a SinkPAD - no telling yet, still early... Very interesting to watch this data fill out...
relic38
relic38's picture
FP, I just filled out the survey at SinkPAD, one more product to compare to (eventually).
Tom E, that blip at 5.4A is when the light meter went from the 20,000 lux scale to the 200,000 lux scale. I believe the 2,000 and 20,000 lux scales read slightly low on my meter. Nothing drastic, but noticeable.
I’m avoiding interpreting any data at this point. Once I have more data from more tests and can compare to other direct-bonded stars.
One important note is that in statistics, a sample size of one is mostly useless. There could be some undetected defect in that sample, or it could be a stand-out performer. Either way, the test results from one sample are likely not going to represent the average performance of a mass-produced product. Product characterization requires several samples from several production batches to average out those anomalies.
But alas, we live in the budget world. I would not expect a supplier to sent multiple samples from two production runs, nor would I have the time to test that many. We work with what we have and as long as we are aware that the data is limited, all will be OK.
One thing I would not like to see is someone read through the review, see the positive test results, order a bunch and have them comparatively under-perform and then blame the review for misleading them. This potential issue exists with any product review of one sample. Most reviews out there are just that.
[\rant]
I will make one observation though; these stars perform much better than a standard aluminum star. That I am confident in saying.
Welcome the night.
garrybunk
garrybunk's picture
Last seen: 2 months 19 hours ago
I was curious too about the Vf data.  Seems good cells (i.e. Sanyo 2600mAh) in single cell lights could sustain regulation at drive currents up to about 2.8A.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
Tom E
Tom E's picture
relic - +1, agree on all points... Scale change explains the 5.4A hitch.
relic38
relic38's picture
One other note Tom; on Match’s data, it is not clear where Vf was measured at. I measured directly across the star wire pads to eliminate wire drop.
I will be testing the drop across the star traces as well. It is possible that the IS-DCB star traces are thicker than the ones on a SinkPAD (I have not compared them yet). That could also be a contributing difference in Vf.
Actually, I just did a quick comparison of the four XM-L DCB stars I have:
  • SinkPad 20mm star (what Match used) has a ~1mm trace ~5mm long from wire pad to emitter pad, both pos and neg.
  • SinkPAD 16mm star has a ~2mm trace ~2mm long from wire pad to emitter pad, both pos and neg.
  • Noctigon 20mm star has a ~4mm trace ~4mm long from wire pad to emitter pad, both pos and neg.
  • IS-DCB 16mm star has a ~3.75mm ‘trace’ ~2mm long from wire pad to emitter pad, both pos and neg.
Curiosity got the best of me, so I went ahead and tried a quick current test. 6A driven directly from the wire pad to the emitter pad. Multiply by two to get the total voltage drop on the star traces.
  • SinkPAD 20mm star: 43mV (7.1 mOhm)
  • SinkPAD 16mm star: 21mV (3.5 mOhm)
  • Noctigon 20mm star: 22mV (3.7 mOhm)
  • IS-DCB 16mm star: 14mV (2.3 mOhm)
Nothing conclusive, as I need to do this a little less ad-hoc. It does indicate how Match might have gotten a higher Vf reading.
Edit: It has been pointed out that comparing trace resistance of 16mm boards to 20mm boards is not entirely fair. I tend to agree with that, and was not suggesting anyone do that with this data. I recommend limiting comparisons to within the sizes of the stars.
Welcome the night.
Firelight2
Firelight2's picture
Last seen: 10 hours 34 min ago
Interesting. So the preliminary results suggest that the traces on the Illumination Supply stars have the least resistance.
Tom E
Tom E's picture
You know, this could change some think'n around here, that the bigger the star, the better. The 16 SinkPAD is half the 20, and the IS one even better, hhhmmm.
djozz
djozz's picture
The difference between the best and the worst board is 0.7V, at lower currents that will be lower. That is important stuff for the fine-tuners, that means I am ok Wink.
Even though it may not be of much relevance to my mods, I love data, the more the better, keep it coming Smile!
simplec6
Last seen: 7 years 3 months ago
Cool thread. Thanks for the testing, Keep up the good work. You are saving many of us money with this data.
Werner
Werner's picture
Last seen: 3 years 2 months ago
Where do you see the 0.7V?
I would like to see a comparison before and after dedoming
kevind43
Last seen: 3 weeks 1 min ago
watching closely.
Hikelite
Firelight2 wrote:
relic38 wrote:
... Curiosity got the best of me, so I went ahead and tried a quick current test. 6A driven directly from the wire pad to the emitter pad. Multiply by two to get the total voltage drop on the star traces. * SinkPAD 20mm star: 43mV (7.1 mOhm) * SinkPAD 16mm star: 21mV (3.5 mOhm) * Noctigon 20mm star: 22mV (3.7 mOhm) * IS-DCB 16mm star: 14mV (2.3 mOhm) Nothing conclusive, as I need to do this a little less ad-hoc. It does indicate how Match might have gotten a higher Vf reading.
The 16mm boards have the lowest resistances because, well the traces are shorter.
Slewflash
Slewflash's picture
Last seen: 1 year 4 months ago
Insanely good data, good job relic!
Slewflash
Firelight2
Hikelite wrote:
Firelight2 wrote:
relic38 wrote:
… Curiosity got the best of me, so I went ahead and tried a quick current test. 6A driven directly from the wire pad to the emitter pad. Multiply by two to get the total voltage drop on the star traces. * SinkPAD 20mm star: 43mV (7.1 mOhm) * SinkPAD 16mm star: 21mV (3.5 mOhm) * Noctigon 20mm star: 22mV (3.7 mOhm) * IS-DCB 16mm star: 14mV (2.3 mOhm) Nothing conclusive, as I need to do this a little less ad-hoc. It does indicate how Match might have gotten a higher Vf reading.
That makes sense.
Relic … could you test the resistance on a 16mm Noctigon?
relic38
relic38's picture
Funny you should say that. I have been asked by Hank from Intl-Outdoor to do just that. Since I do not have any 16mm XM Noctigons, he is sending me samples.
Hikelite, you are correct, 16mm boards do have shorter traces. However, good trace design can greatly reduce the resistance. Take the two 16mm samples I provided above. The Sinkpad has a thinner trace than IS-DCB and it shows in the test results. The same can be said about the 20mm boards.
As I noted with an edit in the original comment, it is not entirely fair to compare a 20mm board to a 16mm board.
Welcome the night.
