The beam is similar. Both lights are very powerful flooders with great throw too. My brother and I were just out playing with them last night. The TK75 is a flood monster that still throws well. The shocker is a floody light also but throws with a TN31 even in stock form. His modded one just accentuates those traits. As for getting the shocker modded, I more than likely will get both lights done. I personally think they complment each other well.
Thinking about it now, you must be right, I just assumed the cells weren’t fully charged and that light was just getting flat, I did notice after a while it was not as bright, I just mistakenly it seems assumed the ramp down was instant.
Thanks for clearing that up for me, I’m off on the same torch walk tonight, 2nd best hobby I’ve ever had this is, I like RC flying, but always get things stuck up trees ha ha.
tabs
I ordered some new high-discharge cells from FT for this, just to see if I can get a little more out of it. Using my dead BTU original driver, I can get over 5A from the Sanyo ZT cells. I am using the DRY driver right now, which I’m not really a fan of.
tkmclay, I could do the XM-L2 mod, I did it to mine. Only issue is timing. I cannot say when i could do it though. PM me if you are interested in having it done in the next month or two.
What batts? I don't understand -- using a dead BTU driver you get over 5 amps?? I'm confused... Did you do any lumens/throw measurements? Assume you got XM-L2's on copper?
Ohh - I'm all confused... But interested if he was able to re-produce what I seen. Just haven't had a chance yet to mod the next Shocker same way to see if it can be re-produced... Really would have been better for me to do a lot more testing/experimentation with it while I still had it...
Tom E, OK I’ll try to de-confuse things a bit.
Regarding the new cells, I ordered higher discharge rate cells “(Pana PDs)”:https://www.fasttech.com/products/1233700 to see if they can hold a better voltage under load than the Sanyo ZTs. Fasttech sent them by SingPost, so I hope to see them before August…
Regarding my BTU driver, I fried it a while ago and it turned into a single-mode ‘driver’ that delivers a lot of current (over 5A). I decided to swap to a DRY driver, which is not delivering nearly as much current.
I still have the issue of lower output than your tested BTUs (stock and modded) at the same drive current. I am not trying to address that at the moment. Right now, I want to overcome the potential issue I have of lower drive current when running on cells. That is what the new cells are for.
I may also take a closer look at the DRY driver for any resistance mods that can be done.
ohaya, I meant the driver is now a glorified piece of wire.
I think I reversed the polarity on it and that caused it to release some magic smoke. I still have it intact in a bin of replaced drivers, but there’s no physical sign of damage that I can see.
simplec6, the easiest way to lap a star is to use gradually finer grits of sandpaper on a flat surface. For each cycle, sand the bottom of the star until it has a uniform finish. Then repeat with the next finer paper. I finish off with a mirror-like finish at 2000 grit. Others continue to 2500 grit.
Based on this result, I think 2000 grit is acceptable.
Neither do I
In reality, you don’t have to go that quite that far. I just figured I might as well since I was a few hours in already, what’s another 20 minutes
I’m sitting here at work, waiting very impatiently to get home and play with this Shocker Tom E modded for me. I have a sucky point and shoot camera, but I might try to figure out how to take some comparison shots with my other throwers (TN31, TK70, Flexcandles Asgard). Unfortunately, I do not have a lux meter, so I can’t do any lux testing either
I will, however, be happy to test the current at the switch with some different batteries. I have the Samsung INR18650-20R batteries which have a rated max discharge of 22 amps. I also have some NCR18650PD’s on the way, but they probably won’t be here for a week or two. I will try and post as much info as I can.
A big thanks to Tom E for modding this light for me! I absolutely cannot wait to get home and play with this thing.
A tip from the CPU heatsink lapping savants: Go to a local glass shop and ask if you can have a piece of thick (5/8” to 1”) scrap glass. It is the flattest, hardest, least flexible surface you will find and is about as good as it gets for making sure your lapping is completely uniform and flat. If you want a mirror finish after using sandpaper, you can polish it with some 3M rubbing compound.
There’s no way I’d ever be precise enough to get three emitters perfectly aligned in the reflector holes while soldering them down. I’m sure it can be done, just not by me.
