The World's Most Advanced AMC7135 * 8 Driver
Haha.. Alright, I'm not really sure it's the world's most advanced, but It's pretty awesome.. And yes, it will be available for purchase to people in the BLF community..
So, what is it?
  • 17MM Diameter (Technically, 16.8MM +/- 0.1MM)
  • 8*7135 (380mA each) 3.04A Driver
  • Each AMC7135 Individually addressable (means 8 Steps of Brightness with ZERO PWM)
  • Optional PWMing of one chip gives 1023 levels of brightness in between EACH of the 8 Steps above
  • When in use, PWM Frequency is 7.8Khz
  • FULLY Programmable. Pick your modes, pick your order, select memory or no memory, tons of options.
  • Moonlight Mode WITHOUT PWM (2mA Current) (Can be changed by replacing one resistor)
  • Can be programmed to change modes via Power Cycle (Standard Tail-Cap Clicky) OR via a Momentary Contact (Side-Switch)
  • Temperature Monitoring (Programmable Temperature) (Either shut-down or reduce brightness can be programmed)
  • Voltage Monitoring (Programmable Voltage) (Either shut-down or reduce brightness can be programmed)
  • Voltage Warning (Two Programmable Voltages that will output a blink sequence alerting you that the set voltage has been reached)
  • Modes are locked based upon OFF time rather than ON time (Much Nicer Mode Locking)
So.. Ok.. It's cool so far, but not that cool, right?
What makes it so awesome? It's got a micro USB Connector on it. Yep. USB Programmable. No Clicking through 8 bazillion menus, no need for a Chip-Clip and AVRDude. No Compiling your program in AVRStudio. Just Plug it into your USB Port, Launch the custom application I wrote, Select all your options from drop-down menus, and click "PROGRAM". Presto. Done.
This is what happens when PilotPTK has more than 20 minutes of spare time :)
When's it going to be available? Soon.. I have a bit more to tweak on the software. Hardware is done. As soon as I'm sure the software is going to work without any hardware tweaks, I'll order a bunch of circuit boards and parts.. Once I'm closer to being ready to actually sell them, I'll create another thread in the For Sale section..
Some Photos:
AMC7135 Driver Detected by Windows. Getting Microcontrollers to communicate natively via USB is an exercise for a masochist, I might add:
Top Side of Driver:
Bottom Side of Driver:
Even with USB Connector - Driver still fits just fine in a P60 Pill (Cut-away so you can see in)
Subscribed!
Put me down for one (possibly more depending on the price)! :D
Subscribed and put me down for one
Oh, and how much for the spac navigator? I'd like to be the first flashaholic to orbit Uranus
This sounds fantastic!
Will it be possible to "limit" the maximum current through software to make it suitable for XP-E/G or Nichia 219 for those who don't want 3A output?
I hope you can find a way to sell or patent this to some of the manufacturers who continue to offer that crappy H-L-S option.
Oh! Nice! :slight_smile:
This may be a noob question but is it possible to stack additional AMC7135 chips in it?
I imagine you could just keep high mode set to 6 chips, or what ever you want max
You had me at the 4th bullet. You are a driver god to whip this baby up in short order! The only way it could be better is to make an optional version that works with an electronic switch. You are the MAN!!
Can't wait to see it finished. I'm in for at least one and probably several depending on price. ;)
Subbed! :bigsmile:
You had me at the title page.
I’m in for a couple
Johnny, check out the 8th bullet
In for a handful!
Edit: This is seriously the best announcement all year. Trumps the XM-L2 hands down. PilotPTK you are my idol.
You might want to make it a smidge over 17mm so it can be used in press-fit aluminum bodies. Sand to fit…
WOOHOO!! Not sure how I overlooked that one. :smiley:
Woohoo! Christmas comes early. Way to go Dallas!
Wow. You are certainly one clever bugger. Nice work does not say what you have done justice.
Maybe, but wanting to know if there is way of noobie/kid-proofing it?
Wow!
This driver sounds awesome!!!
I’d be in for anywhere from 2-5 depending on the price.
Frickin awesome. :D
So.. it would also be possible to adress individual LEDs? Running light on quads or triples for example?
I'm pretty sure I'm in for one.
