I’m in for a couple
Johnny, check out the 8th bullet
In for a handful!
Edit: This is seriously the best announcement all year. Trumps the XM-L2 hands down. PilotPTK you are my idol.
You might want to make it a smidge over 17mm so it can be used in press-fit aluminum bodies. Sand to fit…
WOOHOO!! Not sure how I overlooked that one.
Woohoo! Christmas comes early. Way to go Dallas!
Wow. You are certainly one clever bugger. Nice work does not say what you have done justice.
Maybe, but wanting to know if there is way of noobie/kid-proofing it?
Wow!
This driver sounds awesome!!!
I’d be in for anywhere from 2-5 depending on the price.
Frickin awesome. :D
So.. it would also be possible to adress individual LEDs? Running light on quads or triples for example?
I'm pretty sure I'm in for one.
How many extra chips can be stacked on it? 8, 12, 16, before there is an issue? I'm thinking of those guys that like to hod rod everything.
Sounds really fantastic so far. Great accomplishment.
As it is now, I doubt that would work as that would require a ton of extra output pads, but I imagine with some careful soldering that could be done.
I'm pretty sure that would be like a normal 7135 driver, as many as you can fit on it. ;)
There is always some soldering involved. ;)
Exactly what I have in mind when I was doing my DIY driver.
If only you can place the USB connector on the VBat spring side so that you don’t have to remove the driver to re-program. Love it!
This and texaspyro's SRK driver are going to make me very happy with my flashlights.
depend on it price maybe i’ll take 1 :bigsmile:
Wow! That's great news!
Please put me down for some, like 5-10, of these. Depending on the price, of course. :)
When the price isn't mentioned, I always assume the worst... but if it's around some number which I am not going to mention lest it be ridiculously over or under the actual you can count me in for some as-yet unspecified quantity.
What's next? Programmable 12-18v buck driver? (please?) 0:)
That is a fantastic driver for almost every need. But my first thought was: when every 7135 is individually controlled, by cutting some traces this can custom control the color mce/xml
Yes, absolutely. You can turn on 1, 2, 3, 4, 5, 6, or 7 Full AMC7135s plus run the 8th one between OFF and ON in 1024 increments (PWM).
PPtk
