Texaspyro's Handmade Multi-Emitter DIY Contest Entry
The flashlight body is made of 98mm diameter high power rocket phenolic airframe tube laminated with 4 oz 1Kx1K (1000 fibers per bundle) 24x24 (24 bundles per inch) tight weave carbon fiber cloth. West System epoxy was used to do the lamination. I used their “Special Coating Hardener” with the epoxy resin. The Special Coating Hardener is magic stuff. It causes the epoxy to cure to a smooth, self-leveling, optically flat surface.
The tailcap is made of the same material. A piece of phenolic coupler tube (telescopes with the airframe tube) is used to do mount the tailcap. A plywood disk laminated with the same carbon fiber cloth seals the back of the tailcap. The light tailstands just fine. It makes for a dandy candle…
An electrical equipment rack handle is used for the flashlight handle. The handle position was chosen so that the batteries and reflector counterbalance each other. The light is controlled by a small tactile switch mounted on the handle. I’ll probably add attachments for a shoulder strap…
The body parts:
Ok, here’s the finsihed light. It weighs 7.5 pounds (3.4 kg) with the batteries. It balances perfectly at the handle and feels much lighter than 20,000 lumens. Tactile switch is at the top end of the handle. You can see the vent holes for the forced air cooling. Shown with a Sky Ray King cowering in its’ shadow:
And a picture of the LED array in the reflector (before I cleaned up all the finger prints). Temperature sensor is under that grey glob of thermal epoxy.
Beamshot against a very light beige wall. What isn’t obvious is the wall is over 10 feet wide and the light was around 4 feet from it. It was pretty much fully illuminated. The camera makes it look like there was some variation towards the edges. The beam is around 120 degrees wide with a small hotspot. The thing has almost NO throw, all flood… flood of biblical proportions. Enough flood to make Noah despair…
Getting ground based images of the beam of this thing is rather hard. The beam is over 120 degrees wide. It hits the ground near your feet and the foreground gets rather overexposed. Here is a double wide soccer field:
Ok, let’s try something a bit more vertical… how about a five story bank building? Without the light, the thing pretty much photographed as black. How far away was the camera? Try across the street… oh, woe is Noah…
For some strange reason, that streetlight is not on… I could have sworn that it was… J)
Cast of characters:
Materials:
Bridgelux C9000 array: $55
Mikasa pasta bowl (and two others): $75
Custom driver: $25
Batteries: free from a RC pilot friend… a bit worn out ($135 new)
Wire and connectors: $5
Phenolic tube: $10
1/4” aircraft plywood: $3
Nuts, bolts, washers, standoffs: $5
Diamond paste: $1 (out of a $10 syringe)
Carbon fiber cloth: $10
Epoxy: $5 (out of around $80 cans)
High Density Epoxy Filler: $1
Epoxy squeege: $1
Foam brushes: $3
Sandpaper: $3
Paint and primer: $20
Acetone: $5
Vinegar: $5
Lye: $1
Tools:
Screwdriver
Nut driver
Coping saw
Wire bush
Automatic center punch
Drill and bits (3mm, #6 screw, 1/2”)
Soldering iron (used a butane one to minimize use of power tools)
Ruler, marker, compass
Coda:
This is a rather useless light unless you want to light up the side of a building/tall tree/canyon or light a playing field/worksite from above. The beam is SOOOO wide, most light is wasted on your feet and the sky. It needs a much more reasonable reflector. It will probably be redone with a commercial copper CPU heatsink and reflector like in: 15,000 Lumen Bridgelux C9000 Light Engine
Speechless. I’m not sure what I just read but wow. Have I just read the ramblings from a freak, poet, mad scientist, genius, creative fool or a light junkie. I reckon theres a bit off all the above mixed together to create this new sun that is about to illuminate the daytime.
I take my hat off to you texaspyro and there is no insult at all intended with the above. I literally stood up and gave you a round off applause. Well done so far. Cheers.
Sorry Texas, no harm meant
Cant wait to see that driver in use
edit mrsdnf:
edit: mrsdnf
A little waiting doesn’t hurt, especially with good music! :wink:
I’m quite curious now. :slight_smile:
ok, I'm all eyes, love the intro music already, awaiting the rest...
I should have reserved more posts.
I sense further/impending epicness.
You can't go wrong with Led Zep!
Reserved post for future comments…
EDIT now that the build has been revealed!
That light is just sick!
Something really different. Looking forward to see beamshots!
With the one post per minute limit, it’s really hard to reserve 5 posts without some sneaky person sneaking in a post between them… :wink:
Hehe... Sooooooorry
I’ve seen a hint or two of what you are planning here. So many secrets. I do know that there will be a lot of power involved. :slight_smile:
I was so tempted...
Don't let it kill you baby, don't let it get to you
Don't let 'em kill you baby, don't let 'em get to you
I'll be your breathin' heart, I'll be your cryin' fool
Don't let this go to far, don't let it get to you
The waiting is the hardest part
Every day you see one more card
You take it on faith, you take it to the heart
Hey tp, got any reservations about your build?
I reserve the right to be reserved about my reservations…
Updated the first few posts with some build info and pictures…
“Something to blind the Dragon of Darkness” — or shoot an annoying helicopter out of the sky. :smiley:
I like the bowl, it gives a nice touch with it’s decorations. :wink:
That surely is a lot of work! But I have the feeling the reward will be the giggling worthy of a whole flock of schoolgirls. :wink:
Comment in post five. :slight_smile:
