I was fiddling around with a light today. I didn't feel like doing much, so I figured I'd add some braid to the tailcap for something to do. When I took it apart, it wasn't much of a switch. A loose spring resting on an aluminum contact all held together by the brass cap torqued down with a nylon washer. Non of my extra switches would fit in the setup, although my McClicky was just a hair away from threading in perfectly.
Since it was apart, I added braid to the spring. I know relic didn't find those brass spring caps to cause any real impedance, but I thought, copper must be better than brass.
I drilled a hole through the brass cap and stuck a piece of 20AWG wire through the hole. Next I separated and splayed out the wire strands so they would mash up flat against the inside of the cap, added flux and heated up the cap. I let the solder bubble and pool evenly and then get sucked up the wire through the hole.
Looks good. Snipped off the excess, ground it flush with the dremel and used the buffing wheel with some knife stropping compound.
i know it really won't have any effect on this particular light, but I like the idea af having the battery contacting copper, which contacts with the braiding on the spring. I'll try this with my builds where I'm trying to tweak things max and mininamalize resistance. I guess you could also take off the brass cap and throw it away. Next time I'll try it with 14 or 16 AWG wire. It can't hurt, and gives me something to putter with.
Yes, that's what I've been doing to remove any flux that may be in the braid. I'm still not happy with the braid I'm using though - don't feel confident it will hold up in the long term. For some tailcap springs that don't compress much, it's fine, but doing a Shocker battery carrier where compression is extreme with long protected batteries, it takes a beating... I've switched between KP 3400's and Pana PD's, and the difference is extreme with those springs - Pana PD's barely touching it seems like, KP's just about fully compressed.
You could try flexible silicone wire attached outside the spring. I found the spring compression very tight with protected Panasonic 3400 and Sanyo 2800 in the carrier of my EYE40. I found these protected Panasonics fit nicely.
Interesting, I should try those. But I'm trying to be universal - I don't own a Shocker, but mod'ed like 8 of them, so figuring the KP 3400's are worse case. Silicone wire on the outside might be better in a wrap-around setup, not straight up-down (too much flexing on the solder connections) -- maybe I should try that...
I think they will be OK. Berillyum copper is considered toxic (dust and fumes, not solid metal), so the silver plating serves two purposes. I think I have some uncoated ones and I don’t bother with braid on those. If I can confirm they are b-copper, I’ll post a link.
THE-day, the ones you linked would need to be cut shorter, they would be unstable at that length. I would guess up to 1/2 inch or so would be OK, maybe just cut in half.
I did it on my KDC8 and my solarforceL2N tailspring thanks for posting thread on thisn I did with out any major calamities befalling me or poor light thanks again.
DenB, I received my replacement F13 that I bought a while back, after the giveaway. It was DOA… I took it all apart and put it back together. It is fine now. :~
Doesn’t matter much, since I’ll replace most of the guts with new guts.
They’re properly called “Flush Cutters”. These are made of plate steel, bent and sharpened in all the right places. At some point, at the moment you cut a wire, one of the jaws will fly off with a pop. It won’t hurt unless it hits you IN the eyeball, but it’s going to happen.
I use these at work to cut Cat5/Cat6 ethernet cable and occasionally other low-voltage copper cables. The plate-steel arms fail right at the edge of the hinge. Since it happens at the moment of greatest impact in a cut, the result is quite violent, for such a wee bit o’ metal. The flying jaw still has a sharp point and edge, but they don’t tend to fly too far so I doubt they’d stick into anything. They’re cheap enough, I don’t even bother with returning them “under warranty”, usually.
If you’ll invest in a bigger, tougher “semi-flush” cutter, it will handle all but the finest flush cuts, which will be done by this one, all of which will extend this one’s lifespan significantly.
If you take care of a good set of flush cutters, they can be a most awesome tool, regardless of the price… (try it — gently — next time you get a stuck splinter or metal shard…)
Thanks relic38, after I posted I realized they weren’t the perfect size.
Well I was able to find some silver plated copper springs on an old CPF thread which are the right size.
I’m hoping there are still some left.
Btw, whats your opinion on stiff gold plated springs? Are they good enough to reduce resistance?
The stiff gold plated springs are usually steel-based. Very high resistance. The gold plating does help a, but mainly prevents rusting. After testing them, I end up putting braid on them.
Edit: I modified this statement slightly based on the test results below.
I tested what I believed to be copper alloy (possibly beryllium copper) springs that I got from Fasttech . The are definitely not steel and according to Fasttech they are made of “carobronze”, a brand of copper alloy alternative to beryllium copper. Whatever they are, they exhibit superior performance over standard steel springs that we often see on drivers and tailcaps.
I also tested similarly sized chrome-plated and gold-plated steel springs that I removed from flashlights or were on some switches I had.
All three were tested at 5A and the resulting voltage drop across the spring itself was measured. The measurement was taken after the voltage settled due to any heating of the spring.
Copper alloy spring: 114mV at 5A = 22.8 mOhm, no significant heating, warm to the touch.
Gold-plated steel spring: 301mV at 5A = 60.2 mOhm, spring got very hot and started to smell but no visible smoke.
Chrome plated steel spring: 680mV at 5A = 136 mOhm, spring began to smoke and melted my J-clip before I noticed and stopped the test.
Not exactly definitive or comprehensive, but good enough for me. These springs are only about 12-14mm tall, so not the best for every application. I used three in my Copper DIY build, and I am happy with how they work there.
Copper braid/wire can help all three types, but there is a point of diminishing returns, so I only recommend augmenting the spring types that get all hot and bothered if you do not do it.
I de-soldered the driver spring first, and then tried to solder it back with the copper braid attached......
That wasnt much fun... and it took me quite some time, and it doesnt look good, plus the copper braid got quite a bit of solder in it, so it isnt that flexible anymore... hopefully it will hold up.
