This is soon a real review.. Just don't ask for beamshots yet.. ;)
About 15.5mm
Outer diameter 46.0mm, depth 40.0mm.
Inner diameter 43.0mm.
Bezel inner diameter 42.0mm.
About 15.5mm
No idea, yet. As I said, the output was sagging at 30s point, so full 600lm can't be kept for any longer. This was not thermal sag, but voltage sag of my Eneloop XX 2500mAh.
I'll publish both 26650 and AA runtime graphs in the real review. Please wait patiently. :)
I haven't measured the tailcap current draw with AAs, but calculated runtimes with 26650 are:
1h20min on high, 4h40min on med, 80h on low (over 3 days), 1000h on moon (over 41 days)
thanks. i dont see an issue of a 16mm boot in a 15.5mm hole. done 16mm in a 14mm before
Yo where the beamshots at?
Looks sweet. Would love to see some shots of the tint.
i really want one of these
will it fit unprotected 26650 ok? i have a mnke 4000mah imr that would go well in this light
Ok 'the', sooo convincing - ordering the 6C1, along with some of Hank's great deals on the XM-L2's on Noctigons, even though I literally have 26 bare Noctigons right now...
Some runtimes on a 18650 also please
Nice!This light is def. living up to the hype.Now I just have to convince myself that I don’t need another light.Really, I don’t.Although I do have two homeless unprotected 26650’s, and I am still upset about my defective SF S2200.Hmmmm….
I am also wondering if long 26650’s fit - the Keeppower 26700s?
In fact is more like 26710. If that existed.
Nite who sorry? I absolutely cannot wait to get mine now, its on the way, I expect it’ll turn up late next week or early week after, Its getting dark sooner here too, get in!
10 lumen brightness continues over 3h mark, I just aborted the test there.
During the 10 lumen period it's possible to switch back to high with a single half click. High is then on for 2-3s and steps down back to 10lm emergency mode. This can be repeated as long as the batteries last.
going to have to buy some eneloops now I guess god damm you. :bigsmile:
if my 26650 will fit im going to buy one!
Thanks for the well organised preview. Impressive light. Even on AA.
Yes, that ten lumen low for extended time is a very nice safety feature. I'm becoming very tempted...
the, as usual, nice and informative review.
But you people have to stop doing this to me. I have just donated another $45 to Mr. Hank Wang’s bank balance
Wow this looks great. These should be the standard mode spacings on all lights.
the thanks! Looks super on AA
That photo is a bit misleading.. The spring mod is only on battery carrier negative spring. Doesn't help 26650 usage. [Frankly, doesn't help lot in AA usage either - rumor says Hank is even going to remove it from further versions]
It should be noted that it really is negative spring. Positive end of the carrier doesn't have a spring, which fools me to try to put the carrier in the wrong way around. Carrier spring towards the tailcap is the rule with this light.
