I am also wondering if long 26650’s fit - the Keeppower 26700s?
In fact is more like 26710. If that existed.
Nite who sorry? I absolutely cannot wait to get mine now, its on the way, I expect it’ll turn up late next week or early week after, Its getting dark sooner here too, get in!
10 lumen brightness continues over 3h mark, I just aborted the test there.
During the 10 lumen period it's possible to switch back to high with a single half click. High is then on for 2-3s and steps down back to 10lm emergency mode. This can be repeated as long as the batteries last.
going to have to buy some eneloops now I guess god damm you. :bigsmile:
if my 26650 will fit im going to buy one!
Thanks for the well organised preview. Impressive light. Even on AA.
Yes, that ten lumen low for extended time is a very nice safety feature. I'm becoming very tempted...
the, as usual, nice and informative review.
But you people have to stop doing this to me. I have just donated another $45 to Mr. Hank Wang’s bank balance
Wow this looks great. These should be the standard mode spacings on all lights.
the thanks! Looks super on AA
That photo is a bit misleading.. The spring mod is only on battery carrier negative spring. Doesn't help 26650 usage. [Frankly, doesn't help lot in AA usage either - rumor says Hank is even going to remove it from further versions]
It should be noted that it really is negative spring. Positive end of the carrier doesn't have a spring, which fools me to try to put the carrier in the wrong way around. Carrier spring towards the tailcap is the rule with this light.
As I mentioned earlier, the lens is very clear. Re-checking it now in a direct sunlight shows signs of some kind of coating.
It's not as purple as I have used to see in AR coated lenses, but it shows fingerprints "better" than uncoated lens.
So I decided to test initial OTF lumens with and without the lens and the results were good: Lens cuts only 1.6% (13lm) and performs like an coated lens should.
I think I need to admit my mistake: The lens has (some kind of) AR coating and it performs well.
Sorry about causing unnecessary hassle.
No side switch?
(nothing is wrong with this light, just that I might be too picky…)
no, i prefer side switch lights too that would have been icing on the cake
that said, i think i bought one days after it was released
I have a lense just like that the its in the oem d5, no sign on the specs of coating, never noticed for MONTHS it was coated, went to take a picture one day and spotted it, now I don’t know how I missed it.
Getting really eager to get this light now.
Thanks for clarifying the.
Glad to hear it is a good AR coated lens.
This X3 looks like a real winner. Thanks for the review.
Sorry. Won't fit. :(
I used King Kong 4000mAh in my tests and (as unprotected) it worked fine. Now I tried TF 26650 "5000mAh" and that's too long at 68.5mm. Same applies to XTAR 18700.
What about the 18650? Has anyone tried that?
"3*NiMH, 1*26650 or 1*18650 (only works with the length under 67mm"
I didn't think about this when ordering . Might have to sell mine.
