I understand the idea for having low modes, but doesn't the spirit behind having a 5 x XML conflict with using low lumens modes? Don't you have a smaller, more sane (heheheh) flashlight for that? If it were me, I'd just want a single "blow your head off" mode and I'd paint flames on it.
Ha, yeah, good point. But this Sky Ray might actually become my EDC if the low mode is low enough. My WF-500 is one of my two EDCs right now, the other being a Fenix LD01 (more sensible), but on those occasions where I pull out the big gun, I don't want to have to put it away when we go into a restaurant or something. If I could click it down to say 30 lm, then I could hand it to someone for reading a menu or something. And then if a cockroach scurries across the table, I'll click the light back to High. :)
Another use case: taking the dogs out in the yard at night. I like to have a high High, so I can see skunks, etc., but I also want a fairly low Low, so as not to blind the puppies after I've determined that the coast is clear.
Changing the subject momentarily: does anyone know what effect a super-bright light, or a laser, would have on a spider? I find spiders on the house every night when I take the dogs out. I've tried pointing my WF-500 at them, with no apparent effect. I even tried a 5 mW laser pointer once, also with no effect. I expected the spider to at least run away from the laser pointer beam, but no.
No ****, hey even if its not #$#@ bright, its gonna be bright and really efficient (lower curret to each XM-L). Size seems to be good, helps in heatsinking. Can you imagine only how much current is needed for 1000L from the 3 emitters?
You get a 65W Ebay HID if you want super lots of lumens/wall of light with decent hotspot (and they are focusable), not these. @ 101usd with 6600mAH batteries that last 70-80 mins on high (I tested like > 20 times already, full batt to cut off) they are hard to beat. And they can sustain full batt -> cutoff in a single run without thermal or "explosive" issues. Replacement batteries are cheap at just 40 bucks SHIPPED, they have a 7800mAH version even, ballast are cheap......etc. Yes you heard me right, i have used many times, did like 20 cycles test runs, no explosions during running or charging.
Pls don't be bothered with the specs. We know what a 2x18650, 225mm long, 56mm dia bezel light can do, soak up and spread the heat....and only priced at 52 bucks.
I doubt it'll be much of a thrower - though when you put out that sort of light, who needs throw?
If you see my beamshots of the Romisen RC-T5 and RC-T6 that's what I'd expect, just quite a bit brighter - the RC-T6 is around the 700 lumen mark, the T5 around 450. This one should be pushing 2000, maybe more.
Thanks Don. I'm not a big fan of purely throwy lights, so that's a positive to me. I see you have a stock WF-500. The WF-500 with the 5x XR-E module has a very similar beam shape, but a little brighter. For walking on long, straight paths at night, this light does the trick. You can see pretty far into the distance. But most of the time I'd rather have a moderately wide flood, with so much output that it achieves decent throw too.
With the purely throwy lights, if you're worried about bears to the left and right, you need to keep painting the beam all over the place. I'll use the 3x XM-L for those kinds of walks, and the 5x XR-E for the long straight paths where bears don't go. :)
For XM-Ls on a ~ 25mm reflector to really throw, you'd need brute force with crazy numbers of them, something like the 30pcs custom one on a Thor X Colossus host in CPF's HIDs and Spotlights section. :) (but then the spill will spoil your night adapted vision, and for those in temperate countries definitely not useful in the snow). Seriously its not too bad, like duct taping 3 P60 hosts with XM-L together. Its actually a wee bit smaller than the Catapult V3.
I've ordered one, there is a very high chance this can out throw the UF-980L but still be slightly below a Catapult V3, but the wall of light in a small package would be fun (slots in below my Ebay HIDs). I'll definitely not be able to bring myself to order one from Jetbeam/Thrunite/Olight at the pace LEDs are moving.
One day some company like Ultrafire/Trustfire will come out with a 5 XM-L with 3 18650s or 4 18650 in a holder and price it at $100. :)
Hahaha.....well I guess we flashaholics like it small, small pocket rockets or medium pocket rockets (this Sky Ray 3xT6?). However Ebay sells them at really too high a price. The price dropped to $95 already (45W/55W/65W 3 mode model). Shipping via EMS is usd32 to my place, $21 to nearer places like Taiwan.
But currently the champ is not this, but the Lightpipe 70W model, in which they re-adjusted it down to $135 (it was $125 first, then they whacked it up to $175 as it was really un-doable at that crazy price). Li-ion, 60 min runtime, 4.75" reflector (not too small to impact performance, but not too big). Something like that Mozo. This is a crazy thrower from the hotspot beam pattern. There were shots with it and a Varapower SST-90, out-threw it by quite a magnitude. Shipping within Continental US is $15 I think. They stocked up on a batch of Li-ion packs meant to recharge notebooks (Made in Korea, guess the cells?), once that is gone it will go back up. Hobby packs are cheap...but not that cheap.
Yep, its tailcap activation. Abyway manafont is processing it now, its Saturday but they have a habit of sending it out on a Sunday night as well. Will take some shots vs regular XM-L, HIDs.
Not exactly being sold there but the employess let me take a couple of drill batteries from the battery recycle bin and I found a couple of practically brand new drill batteries which I extracted Samsung and sony IMRs.
gday mate i just did too so we will just have to wait and see & does anyone know whats the best batteries for this torch i have the pcb flame trustfires would they handle this torch cheers & hi to everyone ??
Trustfire Flames shd be ok, but not sure how much are they gonna draw at the tailcap. Remember if each emitter is gonna draw 2.5A, that's 7.5A total. So each cell is gonna be doing at least 3.75A, add some more for driver losses. But we'll have to get it first to see how it goes....it could be more, it could be less.
Others can consider the Solarforce V2 18650 2400, they are only $7 a piece, so that's $14. Just 3 dollars more than the trustfire flames 2400. Batteries are gonna last for a good number of your next new variant LED flashlights. Flashlights change, batteries don't. That said, I have 2 Ultrafires (given to me "free" from my lasers), one 2400 labelled and the other 3800mAH labelled, both are capable of doing 2.5-3A on my XM-L when fully charged and they do last > 1hr on medium (approx 1.25A) so i guess they are "pretty ok". I have the $5 PALight 3000mAH labelled protected 18650 from manafont, pretty ok too.....i think over 2hrs on medium but then during latter stages the current pull could be dropping and < 1A (did not check). Hey, as long as not DOA.
This is esp important for a 2S light like this. So perhaps for starting off, just order $14 worth of Solarforce V2 18650 and be done with it?
I am sure you'd not wanna use Ultrafires/trustfires on a $100 flashlight next time when you upgrade. The good Li-ion shd last a good couple of years (5 at least?) if maintained well.
Or you can use AW IMRs, they are pretty safe. Won't have fireworks.
