Added another Chinese banknote.
I managed to take out the front glass cover of the PT30 (it was screwed in very tightly), seems to increase the UV light intensity by a wee bit. I gauged it by bouncing off toilet paper.
Just to give an idea on UV LEDs (3W 365nm Tank007 PT30) vs very very near UV 405nm 400mW....
First one is Tank007 3W 365nm. Second is Laser diode RAW output. The laser diode output is CRAZY, the hotspot is like spread over 2X of what is visible here. As you can see the top of Doraemon's head is fluorescing brightly. I underexposed the LED so as to accomondate the LD output, in real life it is much brighter than this.
About the lens blocking the UV watch this post below
Still have them? Why did you not send them back for a refund along with the postage?
Wow, with the plastic lens removed it revealed another band of details (the orange ones). For my PT30 the lens is glass, it just cuts maybe 5-10% of the UV intensity...taking it out does not reveal more details.
This is new at the Tank007 store?
http://www.tank007store.com/products/TANK007-E06-1w-365nm-UV-flashlight.html
"UV Led: Japan UV Chip"...
mfm these is UltraFire WF-602C 395nm UV LED Flashlight for only$12.28 at KD
do you think this will be any good?
Looks OK, but it mostly depends on what you want to use it for? For example, It will be useless for checking UK currency.
posted to follow. great post. Thanks for the work.
looks interesting just wondering if that mini microscope 60x really is 60x ? is that one of the cheapies ebay 6$ ones ?
The notes that don’t have the UV so visible are harder to copy. Also you might not be using the correct light to see the marks as it is quite visible on all of the lights except the TK-566. It’s all about using the right wavelength and not shining a tons of blue/violet light at it like most lights did. I think they are still too much in the visible spectrum.
Wow! Awesome thread, thank you for sharing! Where did you get the TK light from?
Has anyone tried the UV drop in from Solarforce? $14.99 for the P-60 type drop in.
- Provide 230 Lumens Max output
- Wavelength: 380 - 450nm
I was just playing with my Inova X5 UV and decided I wanted to see if the UV would make a glo-ring light up better than the regular LED it was installed in.
I wasnt expecting the LED in the light to start glowing but I realise now that I should have.
Anyway after checking out all my lights that are within easy reach and I think I've got a way to verify that the tint I ordered is the tint I recieved.
My warm white LED glowed red, neutral (and some sold as cool) white glowed orange, and the cool white glowed plain white.
Can anyone else back me up on this?
Well spotted!
I don’t have any warm white LED’s but can confirm my Neutral ones glow an orangy/pink and cool ones white.
You could well be onto something here! Gonna watch and see how this develops.
Those pictures of money remind me of fake-money detection devices. :bigsmile:
Took a picture using my 365nm uv led to show what shur found.
On top is neutral, warm and a green led.
The lower ones are all cool white and didn’t show much but there is a Nichia 219 glowing pretty nice bellow the warm white.
I posted this a few times in various threads. I take it that no one has any experience with the Solarforce UV drop in? It is a low voltage 3-4.2v drop in designed to run best on a single 18650, RCR123, or CR123 battery.
http://www.solarforceflashlight-sales.com/product_detail.php?t=RB&s=11&id=44
