Killed my soldering workstation - Get another Weller, or a Hakko?
Go track down a used Metcal unit. Failing that, I’d suggest Hakko.
I have the analog Hakko 888, and I’m quite happy with it. That’s not saying too much because I’m quite the noob at precision soldering, and the irons I had before were crap.
That said, Fasttech has some Hakko compatible tips for really cheap. I haven’t used them enough to have an opinion about durability, though.
Even though I love my Aoyue 936 (Hakko clone), given the choice of the two you posted I’d get the Weller. I prefer analogue control and a larger solder sponge tray. The digital buttons would drive me mad when adjusting temperatures. >.<
I wonder what is wrong inside your Weller.
There aren’t any digital buttons. It’s a knob like the analog, but it controls the digital display. Just twist. Easy as pie.
The Weller (actually, Wellers) that I have are really old, from when I had a business.
One of them had a similar problem way back when. It looks like something inside the pencil shorts.
One of my techs repaired that one then, and I used it for awhile, but it wasn’t working very well, so I started using the 2nd one, which is the one that went south yesterday.
I still have the repaired one somewhere, and I’ll have to dig it out, to see if maybe it was just the tip getting too old, because as I mentioned, I recently bought a bunch of new Weller tips from Ebay.
If that works, I can use that for awhile, I guess, but if not I’ll need to buy a new one.
I've been soldering professionally for the past 40+ years and I have to say this model gets my approval. I own mine 7 or 8 years now. I love it..
BTW, I've been a Weller user since the beginning so I can't comment on other brands..
Where is the knob? I can only see an up and enter button, and the plug below it for the pen:
I don’t like the styling either; it sort of looks like a toy. (No offense to Hakko owners!)
I think ouchy was talking about the digital Weller.
Edit: I think it has a toy-like appearance also :).
pretty much all the new hakkos look like that. They wanted to look different, I suppose.
If you want a decent name brand system I’d suggest either hakko or weller.
If you’re looking to do a lot of important soldering… You can get a used oki/metcal system for under $200 if you keep watching ebay. I’ve got a MFR2200 system myself.
ohaya. Hers how I looked at it. This is a big investment that you will have for years. When I had to decide between the older analog, or the new upgraded digital model, is the difference in money that much for something that I will be using for years. I know that months later, I would have been kicking myself for not getting the newer upgrade. Sometimes it is more frugal to pay a bit extra for a long term investment.
Understood, but no one has answered the question I asked in post #5?
I believe there have been other upgrades as well. I think the heating is much faster…0 to 700° in thirty seconds. I know I researched all over the place about the same things before I bought, but I can’t remember much anymore. Being in Canada I paid a lot more than what you can get it for, and I got a great price. I have no regrets.
Edit: It’s also really helpful when soldering something that initially absorbs a lot of heat. You can observe the tip temperature dropping and rising on the display.
Hi,
Thanks. BTW, the pic for both have one where the pencil tip is pointed at the front panel. Is that for the “wireless” thing, i.e., it senses the actual temperature from the pencil, but you have to bring the pencil up to the front panel?
See edit
No. That was just for artistic placement.
Yep, it show is :)
That does sound handy. I can tell that from my Aoyue when the heating LED stops pulsing and stays on.
Update: I swapped the older, previously-repaired pencil with the main station, and it’s working, so now I at least have a working setup.
So, this gives me time to consider and do some research.
I’m now considering the Weller WESD51 and, based on Chloe’s suggestion, and thinking about this Aouyue:
http://www.amazon.com/Aoyue-9378-Programmable-Digital-Soldering/dp/B00BSW69LI/ref=cm_cr_pr_product_top
That’s actually cheaper than the analog Weller WES51, and, it comes with 10 extra tips.
ruffles,
You mentioned that FT is carrying Hakko compatible tips? Do you have a link? According to the Amazon review, that Aouyue takes Hakko tips!
Thanks,
Jim
Also, forgot to mention: Looking at the blown pencil, there’s a black hole on the cord near where it goes into the pencil handle. I’m thinking either a short or maybe a thermofuse that blew :(.
+1… weller
